Advises needed
paxidorm
Advises needed
Post by paxidorm » Wed Jun 23, 2010 8:03 pm
Gresini
Post by Gresini » Wed Jun 23, 2010 9:27 pm
I suppose high comp pistons suits you more.
Mugen Boi
Location: Lor Ah Soo, Potong Pasir, Bishan, Leng Kee, Hillview
Post by Mugen Boi » Wed Jun 23, 2010 9:57 pm
1. not very sure in comestic head gasket...the thicker the gasket...the lower ur engine compression there4 may or may not lower ur hp n vice versa
2. usually gasket depend on the block
3. skimming the head slightly is juz 2 ensure tat the head is flat, no warpage...compression may or may not increase depending on gasket use n there4 increase in hp is unsure
4. the engine won't vibrate a lot...it juz send the vibration 2 the chassic there4 u'll feel vibration quite easily
