Qns on CP2 mileage km/L after servicing by KM
Honda's latest 8th generation Accord
Cochran
Post by Cochran » Mon Jan 25, 2010 2:11 pm
Hi there
I have faced some issue with my CP2 mileage after serviced by KM.
From 0 to 30000km. my average is ard 9+ km/L
After the 30000km servicing, i am only able to get 8+ ard 8.2km/L thats quite low. Rang the KM service guy to check. The fuel injector was serviced. but should not be causing the problem.
The driving pattern and style did not change.
Did not really care much fr then. But keeping a record of my mileage fr 30000 to 40000km. Average is ard 8.3km/L for the 30k to 40k period. Last week have done my 40000km servicing and wait to see any changes to it or not. Was again told that nothing done to the engine. So now keeping a close look to see if can get back to 9+ km/L. Will KIV for the mileage update.
Ok. As some ppl may know that i do still have the older CM5 with me too. Again. The car was also sent in for servicing last week for the 140000km... And on average the CM5 can get ard high 8 to 9+ km/L. After the last week servicing... the mileage drop to ard 7.3 km/L. Thats too low man.
My qns. Is there something was 'done' at KM? I'm not sure. but i trusted them. Not pointing finger anyway. Just wanna find out the root cause.
Bro with CP2 can give me some update on ur CP2 average mileage? And wat is the KM rating sticker sticked on the show room car ah?
Again if anyone asking. Both car are STOCK! Non mod.
Thanks.
weaver87
Post by weaver87 » Mon Jan 25, 2010 2:17 pm
Hi bro Cochran,
thanks for sharing this info...was about to send car in for my servicing.
My 2.4 FC had not been monitored for a while as I was rather lazy....may be I will checked b4 I send in....on the other hand, I had modded my rims and added stuff, so naturally my FC will be worst than the stock 2.4....but cant be far...to be shared w u later...
Cheers!
stingray751
Post by stingray751 » Wed Jan 27, 2010 11:55 pm
Hi Guys,
I've been keeping track on the mileage, I'm getting an average of 9km/l and at times 10 km/l. But 75% highway subject to daily jams which will cause the car to drink more.
I notice that if you idle the car (waiting time), start / stop traffic, our CP2 will drink.
Hope this helps.
vti magnesium
Post by vti magnesium » Thu Jan 28, 2010 12:59 pm
Hi Bros, my CP2 is ard 10 - 11, Think its not bad hor...
Bro Cochran, wats the servicing price for 40000km? i have just reached.
Think the CP is a bit not up to the past accord.
Batt only ard 30k, Wiper quite fast wear out, car alarm no sound, the insulation and engine noise must bear with it...
But overall, the look is good...
8)
EKen4
S2000 Moderator
S2000 Moderator
Post by EKen4 » Thu Jan 28, 2010 7:22 pm
can perhaps check if engine oil has been overfilled. If ATF has been changed as well, check for overfills of ATF too.
weaver87
Post by weaver87 » Fri Jan 29, 2010 5:19 pm
vti magnesium wrote:Hi Bros, my CP2 is ard 10 - 11, Think its not bad hor...
8)
Bro Vti,
R u sure u r getting 10 to 11 ? I just checked mine and its around 9 only....u must be ferrying those super light girls huh??!! :D :D
cheers!
vti magnesium
Post by vti magnesium » Fri Jan 29, 2010 6:05 pm
8)
Bro Vti,
cheers!
i always reset the meter when go pump. ard 670km.
maybe i dun have the very power audio system in my car...
8)
Quite busy lately... no time to meet up. hope to see you when free.
Cheers
JJ747
Post by JJ747 » Sat Jan 30, 2010 10:48 am
i just got my accord, now monitoring as well.
for the first 130km++, fuel still at full tank, BUT, from 130 - 230 it became 3/4....
so :shock: .
weaver87
Post by weaver87 » Sat Jan 30, 2010 12:05 pm
8)
Bro Vti,
cheers!
8)
Cheers
Sure bro Vti,
R u sure my powderful audio system will take up more gasoline?? haha..
Just to chk if we r calculating on same ground, how much is the gas tank litres u use to calculate yr FC....
I only use half tank mark to calculate cos u cannot drive till full empty tank...
Cheers!
weaver87
Post by weaver87 » Sat Jan 30, 2010 12:07 pm
JJ747 wrote:i just got my accord, now monitoring as well.
so :shock: .
bro, during run in, no sudden push off from stationary position and avoid suddent brake unless emergency....u k go beyond 100km/hr....no worries....not sure, chk yr manual...clearly stated....
Enjoy yr ride and since yr ride so new, k join in the photo shoot offered by CL7 bro....check the thread...
cheers! 8)
vti magnesium
Post by vti magnesium » Sat Jan 30, 2010 5:37 pm
weaver87 wrote:
Bro Vti,
cheers!
8)
Cheers
Sure bro Vti,
Cheers!
i always pump when light lit up.
8)
maybe i always mostly on highway driving also.
Cochran
Post by Cochran » Wed Feb 03, 2010 4:43 pm
Ok. Wah look like most of u all having better FC then me.
For my driving time is the usual morning 7+ jam and evening jam.
think my 40k svc is ard $500+
Ya. i do agree that the CP maybe a bit not as good as the CM. but the look of CP is there. But till now no major issue with the CP yet as nearing to 2 yr liao. (Wah time fly man 2 yr liao in april)
still have not topup my tank yet. ha. now almost 1/4 liao.
My calcuation is based on. after topup will note my distance fr ODO then see how many litre top up fr the kiosk meter or receipt. then distance/litre to get the FC per litre.
weaver87
Post by weaver87 » Wed Feb 03, 2010 5:23 pm
Bros,
Just my opinion...
Our CP gasoline tank is either 65L or 70 L capacity. So if we track our mileage from full tank (auto stop during filling) till mid tank mark, we should use the clocked kms and divide by the 32.5L or 35L....and it should give us a closer accuracy....if use empty tank warning light, there is still some % remain in the tank.
Can anyone confirm our gasoline tank size?
cheers!
stingray751
Post by stingray751 » Wed Feb 03, 2010 5:57 pm
Guy, this is how i calculate (may not be the best).
I will set zero when the fuel needle reaches the half mark (error may happen, but give and take a bit). And at any point when i fill up, i will keep the receipt (because the number of liters of fuel pump in, is recorded). At the point when the needle hits the half way point, before i reset to zero i will record the mileage. Divide the mileage with the liters of fuel.
:wink:
