Question on piggy back ecu...
rango
Post by rango » Mon Jul 27, 2009 8:16 am
any bro can advice if i get a used greedy emanage blue/uultimate etc....do i have to buy from a bro who has same car as me....ie...ek4 cos for different car the wiring and harness is different??... :?
and also roughly how much it will cost to get it hooked up...tks
Shamie
Post by Shamie » Mon Jul 27, 2009 12:35 pm
i beleive hooking it up by the mechs should cost you about 70.
setting the emanage for ur ride may carry a different cost.
this is of course aside from tuning.
in any case just get a wiring pinout for ur ecu if u intend to diy.
see if u can identify the wires in ur car using the datasheet. if u can do tht then it should be quite simple for you.
ThE UgLy SiLvEr OnE!
rango
Post by rango » Mon Jul 27, 2009 1:58 pm
Shamie wrote:i beleive hooking it up by the mechs should cost you about 70.
....i not really into diy...leave it to the pros...need to get my ride tuned up as well...thanks for the suggestions.... :D
