CEL won't go off / take a long time to disappear
fsf
Post by fsf » Tue Mar 17, 2009 6:50 pm
my CB honda civic 92 will take quite some time for the CEL to go off. and when this happens, there will be no fuel feed and therefore my car is unable to start.
stuffs that i have done,
i changed to a brand new relay.
jumped the relay pins 5 and 7 to test if the fuel pump works( yes it did)
checked the MAP sensor readings, gave ard 5volts reading which should be fine.
changed the ACG (ALT) (S) 15 amp fuse
(under dash board)
so does this mean that the only main thing responsible for this is the ECU?
this is the only part which i have not diagnosed yet. have yet to open the ecu to check for any leaking capacitors and such..
UltraBear
Re: CEL won't go off / take a long time to disappear
Post by UltraBear » Wed Mar 18, 2009 1:27 pm
fsf wrote:my CB honda civic 92 will take quite some time for the CEL to go off. and when this happens, there will be no fuel feed and therefore my car is unable to start.
(under dash board)
==> check the error code first... dun anyhow do this do that... with error code, it will tell u exactly what is causing the ECL...
fsf
Post by fsf » Wed Mar 18, 2009 1:51 pm
there is no CEL to begin with. lol
Num3ga
Post by Num3ga » Mon Mar 23, 2009 8:30 am
fsf wrote:there is no CEL to begin with. lol
I suspect a gremlin residing near the ecu and playing with u.Standby the sort pins lah bro when cel pops park and check the codes. Just in case u see the gremlin give it a good slap for fooling ard with u :P
morish
Post by morish » Fri May 29, 2009 11:47 pm
(under dash board)
You can try Mike / 64556268 Kian teong auto centre, he fix my CEL problem after i wasted time and $ with 4 other workshops. He specializes in ecu/electrical diagnosis.. cheers.
sphinx_lover
SHC Die Hard!!!
SHC Die Hard!!!
Post by sphinx_lover » Sat May 30, 2009 2:44 am
There is this relay switch for the ignition. (When you insert your key into and turn). It is located along the key insertion mechanism module which can be seen when you dismantle the low part of your steering wheel dust cover.
EG has this common symptoms that when you turn the key, no CEL appear or will appear much later or will disappear later..this are signs of the ignition switch failure. The cause leads to insufficient battery supply draw by the mechanism from the battery. Without the CEL light being lights up and then lights off, your car will not be able to start.
Replacement of it shd solve yr problem :lol:
Silver
Post by Silver » Sat May 30, 2009 11:59 am
sphinx_lover wrote:There is this relay switch for the ignition. (When you insert your key into and turn). It is located along the key insertion mechanism module which can be seen when you dismantle the low part of your steering wheel dust cover.
UPZ for the master..... :twisted: :twisted:
sphinx_lover
SHC Die Hard!!!
SHC Die Hard!!!
Post by sphinx_lover » Sat May 30, 2009 1:52 pm
haha, im no master to anything lah..jus for sharing :lol:
Silver
Post by Silver » Sat May 30, 2009 11:50 pm
sphinx_lover wrote:haha, im no master to anything lah..jus for sharing :lol:
But the info you shared is veri valuable liao..... :twisted: :twisted:
sphinx_lover
SHC Die Hard!!!
SHC Die Hard!!!
Post by sphinx_lover » Sun May 31, 2009 3:09 am
haha, anyway, yours has been renewed..you can be assured :lol:
Silver wrote: UPZ for the master..... :twisted: :twisted:
Silver
Post by Silver » Sun May 31, 2009 12:06 pm
sphinx_lover wrote:haha, anyway, yours has been renewed..you can be assured :lol:
O... I see.... I learned another thing about this car..... :wink: :wink:
sphinx_lover
SHC Die Hard!!!
SHC Die Hard!!!
Post by sphinx_lover » Sun May 31, 2009 12:33 pm
it shd last you for the next 7-8 years :lol:
Silver wrote: But the info you shared is veri valuable liao..... :twisted: :twisted:
Silver
Post by Silver » Sun May 31, 2009 5:10 pm
sphinx_lover wrote:it shd last you for the next 7-8 years :lol:
Wah... can last so long ah.... thank you!! :twisted: :twisted:
henry_ES
Post by henry_ES » Sun May 31, 2009 8:06 pm
aiya find ultra bear lo.
