RE: Buying a used car, advice needed.
Deioruomu
Post by Deioruomu » Sat Mar 21, 2009 11:10 am
I'm intending to get a car and was told by the previous owner that there's wear and tear at the back suspension rubber that causes a small knocking noise. Can anyone advice what exactly do I need to repair or how much does it cost for the repair?
I'm not even sure what is this rubber thing that the owner mentioned at the back suspension.
I haven't gone down to take a look but will do so soon next weekend.
I thank you in advance for any response.
pgm iv
Re: RE: Buying a used car, advice needed.
Post by pgm iv » Mon Mar 23, 2009 2:49 am
Deioruomu wrote:Hi,
hmm, should be the bushing...go work shop and check...
Num3ga
Post by Num3ga » Mon Mar 23, 2009 8:27 am
If its knocking it could be the suspension mount i thing. Lower rear bushings do not make any sounds. Im driving with worn lower rear bushings.Yes best to take to workshop first to check just a minor repair job.
Deioruomu
Post by Deioruomu » Mon Mar 23, 2009 10:01 am
Thanks for your replies.
The thing is that the car hasn't been bought over yet. The seller told me that the car only has this minor problem. So I'm asking around to see whether the repair will cost a lot.
So is it safe to purchase this car despite its problem? I certainly do hope that it's really considered as a minor problem.
Siao_Liao
Post by Siao_Liao » Sun Mar 29, 2009 4:05 am
Deioruomu wrote:Thanks for your replies.
check out the tips on buying a second hand car in the eg/ek forum's sticky. the info there will be a great help to u.
NSR Sp 2004/5.
RVF 2005/6.
Honda Civic 1.6 2006.
Suzuki GSXR 1000 k4 2006.
if you think u can win me on a car..try me again when i on my bike...
