Civic model year 2000 -2005
Krado
- 7000rpm VTEC ON
Post
by Krado » Sat Apr 10, 2010 4:36 am
MCDS wrote:
*sigh*... stock better...
Actually the reason why I want a SS is because I'm not used to a car that has no exhaust pipe poking out from the back...
Alas, there's always a cheaper solution to my problem... weld weld weld
MCDS
- Civic ES/EU/EP Moderator
Post
by MCDS » Sat Apr 10, 2010 8:29 am
dun touch your stock muffler!!!!! welding wud make it illegal.
cheeper on the long run to buy an 'illegal but quiet' muffler and weld on the exhaust sticking out... caught, just pay fine and change back stock for inspection.
if stock was welded, u have to find another stock that is not modified... may cost big you to get it...
SS2000
- 10 000rpm Over Rev
Post
by SS2000 » Sat Apr 10, 2010 10:43 am
look nice will always cost more $$$$, always maintain orginal will save yr pocket from paying fine n waste time for inspection from LTA
Krado
- 7000rpm VTEC ON
Post
by Krado » Thu Apr 22, 2010 9:51 pm
MCDS wrote:dun touch your stock muffler!!!!! welding wud make it illegal.
Problem solved...
Krado on Fri May 20, 2011 8:27 am, edited 2 times in total.
Krado
- 7000rpm VTEC ON
Post
by Krado » Thu Apr 22, 2010 10:31 pm
ZenithSoul wrote:bolt on?
DaDude said don't waste money mah..............
Eh I PMed u the link for the seller for stock muffler and extractor... got hoot bo?
Krado on Fri Apr 23, 2010 1:27 am, edited 1 time in total.
fred59
- 7000rpm VTEC ON
Post
by fred59 » Thu Apr 22, 2010 10:31 pm
Nice Poking, careful wif your reverse parking
you might leave your tip behind den cannot poke.
Krado
- 7000rpm VTEC ON
Post
by Krado » Thu Apr 22, 2010 10:37 pm
fred59 wrote:Nice Poking, careful wif your reverse parking
Hmph.
Krado
- 7000rpm VTEC ON
Post
by Krado » Sun May 02, 2010 12:40 pm
Hey bro just to share, the official *ahem* bs....
Code: Select all
We have no objection to the fitting of exhaust tail pipe attachment (by way of welding or screwed on) over the original exhaust pipe outlet after the rear muffler, so long as it does not adversely affect the safe operation and emission characteristics of the vehicle. The tail pipe attachment should not be welded directly to the silencer/muffler. You may also wish to note the following points when fitting exhaust tail pipe attachment:
a) the exhaust pipe outlet is installed with sound engineering practice;
b) the exhaust pipe outlet must be adequately supported;
c) there are no modification to the other parts of the exhaust, unless approved by LTA;
d) the exhaust pipe does not protrude longitudinally or laterally from the vehicle;
e) the exhaust pipe outlet should not have any sharp edges and be fitted at the original exhaust pipe position at rear of the vehicle; and
f) the vehicle continues to comply with the applicable noise and exhaust emission standards set by the NEA.
Hehehe.
fred59
- 7000rpm VTEC ON
Post
by fred59 » Sun May 02, 2010 3:56 pm
Point A alrdy very lame, u need sound engineeering to add a tip
No gain wats the point, most of the or rather one and only approved
or non-approved esos are definitely engineered to made
wat else you need, approval tats all.
All craps tats why remain stock dont have to worry so much.
Krado
- 7000rpm VTEC ON
Post
by Krado » Sun May 02, 2010 10:12 pm
fred59 wrote:Point A alrdy very lame, u need sound engineeering to add a tip
Where got... my tip is "
High Performance" exhaust tip ok...
Of course its rubbish lah but... For $20, to see an exhaust pipe poking out from the back... can do lah!
DaDude
- 9000rpm Rev Cut
Post
by DaDude » Sun May 02, 2010 10:46 pm
DDM
DaDude
- 9000rpm Rev Cut
Post
by DaDude » Sun May 02, 2010 10:50 pm
Krado wrote:fred59 wrote:Point A alrdy very lame, u need sound engineeering to add a tip
huh... 20..? lol.... I taut 5 nia... dun buy better...
DDM
Krado
- 7000rpm VTEC ON
Post
by Krado » Mon May 03, 2010 5:26 am
