okie 2 scenerio . both got odo prob ,both have rsm
1st case : speedo not working (mati!!), rsm speed working. using powerfc - handheld speed function working . no checklite.
results:?
2nd case : speedo mostly not working , some times will become crazy swing up a bit but definately not accurate cos i travel highway , it show 10 -30 km/h..... rsm speed NOTHING also ....no powerfc used...ecu checklite will come out after drive a while ... then turn off .. drv again checklite come back ..
results:?
any help is greatly appreciated.
old bird please help: eg6 odometer prob
- 3000rpm
eg9. eg6.ek4.ek9.ef crx. ..ef9..eg2...dc2,...f20..c32b..k20 euroR..k20 fd2R..fn2R..prelude h22a..wah all nice honda cars i want.
Re: old bird please help: eg6 odometer prob
hondavtec1 wrote:okie 2 scenerio . both got odo prob ,both have rsm
results: Speedo meter spoil(likely), connection loose(unlikely)
results: Speed sensor faulty, Socket plug to speed sensor loose or connection problem, Socket plug to speed sensor wet due to water splash
Its most prob ur wiring.. if speed sensor unit spoil, it won't be intermitten... it will all the way hay wire until no more speed indication...hondavtec1 wrote:okie 2 scenerio . both got odo prob ,both have rsm
results:?
results:?
cheers
- SHC Die Hard!!!
- 3000rpm
- Hondamatic
- 5000rpm
results: speedo
results:? speed sensor. Can try to remove the sensor for cleaning. I tried that and so far no problem.
results: speedo
Don bother about the speed sensor 1st... Swop with another car meter and try.... if the swopped in one works meaning meter kaput... if also same then you try speed sensor.
I bought a speedsensor once tot that sensor spoil in the end its meter spoil.... So dun waste money first...
1000rpm. . . . . . . . . 5000rpm
vrrroomm. . . . . . . . VRRAAAAHHHHHHHH
Its the VTEC scream..........
