Engine oil leaking. Pls Help
Hi Bros ,
Anyone Accordian face engine oil leaking on your accord? I am also not sure is steering pump leak or engine oil. But most prob will be the engine oil. Is all over my bonnet, very dirty and messy. Don't know what had cause it to leak. Already change the head casket and spark plug rubber. But still leaking. I don't know how to check as well. Anyone facing the problem too?
Many thanks
Many thanks
Fun Fun Fun.
the item itself is probably $30-$40+..if you look on internet there are some videos teaching how to replace it..price varies from shop to shop.. but if u add about $50 for labour should be around there... typically if workshop can't locate the leak.. they'll normally spray and wash the engine bay and monitor where the leak comes from...Jnco wrote:thanks bro. But do you know what the cost of changing. My oil is everywhere. hard to locate the place for leaking.
Sure and thanks for your help .Will check on the issue.huffie wrote:the item itself is probably $30-$40+..if you look on internet there are some videos teaching how to replace it..price varies from shop to shop.. but if u add about $50 for labour should be around there... typically if workshop can't locate the leak.. they'll normally spray and wash the engine bay and monitor where the leak comes from...Jnco wrote:thanks bro. But do you know what the cost of changing. My oil is everywhere. hard to locate the place for leaking.
Fun Fun Fun.
I had change the seal rubber at the cylinder head, oil pan and spark plug hole rubber. After 1 week, the leaking is still there. I went back to the ws and they use black high temperature silicone to seal for me. They told me , this is the last thing that they can seal up to prevent the leak.snowshake wrote:Seal probably hardened over time. It can be at cylinder head, oil pan, valve and etc.
I know because mine had similar oil sipping issue.
But can be solved
Another problem is my steering pump is also leak. But not much, you can imagine how messy and dirty my engine bay is. lol. My car still left 1.5 years to go.
Fun Fun Fun.
i am driving a CM too.Jnco wrote:Yes CM5. Kah motor told me overhaul est 4k. haahaa. Not worth. I will just continues drive until the engine cannot move. than De-registration the coe, take bk OMV $. Go scrap yard and sell to them.snowshake wrote:Interesting.. Do you consider engine top overhaul?
Pls go to another workshop to verify. I made the same mistake of going Kah, got quoted about 5k. Thought I'd save some money buy buying the parts from stockists. I went to a workshop recommended by Tanly to change the parts.
In the end, the mechanic (formerly from Kah Motors), told me no need to buy this no need to buy that, just recon it. I could have saved another sum just by going to him straight. Lucky I managed to changed the items to engine oil and atf.
Bloody Kah motors!
Thanks for the information, might need you to intro the mechanic. But your cm giving you any problem?fingon wrote:i am driving a CM too.Jnco wrote:Yes CM5. Kah motor told me overhaul est 4k. haahaa. Not worth. I will just continues drive until the engine cannot move. than De-registration the coe, take bk OMV $. Go scrap yard and sell to them.snowshake wrote:Interesting.. Do you consider engine top overhaul?
Bloody Kah motors!
Fun Fun Fun.
everything ok so far. the usual wear and tear...Jnco wrote:Thanks for the information, might need you to intro the mechanic. But your cm giving you any problem?fingon wrote:i am driving a CM too.Jnco wrote: Yes CM5. Kah motor told me overhaul est 4k. haahaa. Not worth. I will just continues drive until the engine cannot move. than De-registration the coe, take bk OMV $. Go scrap yard and sell to them.
Bloody Kah motors!
Bro , my CM5 steering pump oil leak. i need to repair it by buying the steering pump repair kit. Can check where the mechanic you mention at where? i got to know a place can repair. 1 of shc memeber introduce me. By since you say he is ex from kah , should be much more understand the repair than other. Thanksfingon wrote:everything ok so far. the usual wear and tear...Jnco wrote:Thanks for the information, might need you to intro the mechanic. But your cm giving you any problem?fingon wrote: i am driving a CM too.
Bloody Kah motors!
Fun Fun Fun.
hi dropped you a pmJnco wrote:Bro , my CM5 steering pump oil leak. i need to repair it by buying the steering pump repair kit. Can check where the mechanic you mention at where? i got to know a place can repair. 1 of shc memeber introduce me. By since you say he is ex from kah , should be much more understand the repair than other. Thanksfingon wrote:everything ok so far. the usual wear and tear...Jnco wrote: Thanks for the information, might need you to intro the mechanic. But your cm giving you any problem?
