Hi to all CL7A bros,, I understand that majority of you r running on
225/45/17
I personally had tried Dunlop DZ101 225/45/17 ,which is very gd in handling but very noisy ! And 1 of the tyre's side wall burst when travelling on bad road condition ( kana stone) :oops
So i want to know if anyone had try running on 215/55/17 tyres ?
which will be more comfortable and quiet . any advise or suggestion ?
Tks for advise
Suggestion of ideal Rim size & Tyre profiles ???
Re: Suggestion of ideal Rim size & Tyre profiles ???
elias wrote:Hi to all CL7A bros,, I understand that majority of you r running on
225/45/17
Tks for advise
Mich ps3, bs s001, eagle f1a2
- maskedrider
- 5000rpm
225/45/17
Tks for advise
Max can go only 50 instead 55
Correct if I wrong
Kyosho MP9 TKi OS V spec AKA tires Sanwa Blue thunder Spektrum
Yes, thats wat it supposed to be. but my ride is on stock suspension,maskedrider wrote:elias wrote:Hi to all CL7A bros,, I understand that majority of you r running on
225/45/17
Tks for advise
Correct if I wrong
previously bought and it came with 215/55/17 yokohama Earth 1 . It was quiet and more comfortable, reason why i want to be confirmed that this tyre size is ok. majority said it should be 225/45/27 ?????
- jm passion
- 5000rpm
I on Michelin Pilot super sport(http://www.tirerack.com/tires/tests/tes ... p?ttid=141) handling good for dry and wet but noisy currently on size 235/45/17 as long u looking for performance the rubber will be a little more noisy. As for comfort rubber Hankook V12(http://www.tirerack.com/tires/tires.jsp ... 2+evo+K110) quite comfortable for me thread wear quite good as well.
Tks.jm passion wrote:I on Michelin Pilot super sport(http://www.tirerack.com/tires/tests/tes ... p?ttid=141) handling good for dry and wet but noisy currently on size 235/45/17 as long u looking for performance the rubber will be a little more noisy. As for comfort rubber Hankook V12(http://www.tirerack.com/tires/tires.jsp ... 2+evo+K110) quite comfortable for me thread wear quite good as well.
But wat i wan to know is ; can i change to 215/55/17 instead of 225/45/17 ?
my ride is on original stock suspension.
Hi bro, 235/45/17 will bua anot? I on coilover..2 fingers gap. Thksjm passion wrote:I on Michelin Pilot super sport(http://www.tirerack.com/tires/tests/tes ... p?ttid=141) handling good for dry and wet but noisy currently on size 235/45/17 as long u looking for performance the rubber will be a little more noisy. As for comfort rubber Hankook V12(http://www.tirerack.com/tires/tires.jsp ... 2+evo+K110) quite comfortable for me thread wear quite good as well.
