Nothing I have read, anywhere, indicates that bigger brakes will make you stop faster. The OP said his OEM brakes didn't stop him in time and he hit an Audi. I don't think BBK would make a diff in this instance.
From everything I have read, BBK or bigger brake kits are only effective when used a lot, like on a track, and then they are better and more effective with heat.
Why waste the money (unless you're on track or high speed/high barking a lot)?
BBK advise
Sorry bro I beg to differ. I dont track, just some spirited driving and I dont read this or that but what I want to share my experience. First BBK was Spoon, then Alcon since 2007 January, and this is the single most satisfied upgrade Ive done to the car.EasternCanuck wrote:Nothing I have read, anywhere, indicates that bigger brakes will make you stop faster. The OP said his OEM brakes didn't stop him in time and he hit an Audi. I don't think BBK would make a diff in this instance.
If I can do 1 mod to my car only, it will be Alcon BBK, not the cams, not the ECU, not the camber, not the struts and bars etc. A very close fight to the BBK is a good set of tyres.
Cheers
Why everything I like I cannot afford and LTA cannot passed?
Yes, I concur. I remember our bros here giving their feedback before and after installing BBK.hifi1 wrote:Sorry bro I beg to differ. I dont track, just some spirited driving and I dont read this or that but what I want to share my experience. First BBK was Spoon, then Alcon since 2007 January, and this is the single most satisfied upgrade Ive done to the car.EasternCanuck wrote:Nothing I have read, anywhere, indicates that bigger brakes will make you stop faster. The OP said his OEM brakes didn't stop him in time and he hit an Audi. I don't think BBK would make a diff in this instance.
Cheers
It does makes a difference.
Chaning to BBK helps in straight line braking but not forgetting it is making it more fwd brake bias too.
Learning is a journey. There's never an end to it.
- Jeremy(west)
- 1000rpm
Gentlemenss...
I dunno why TS is asking for advice on brands of BBK to change dat got u guys arguing/discussing abt which brand is best???
Fm his initial post, its obvious his car's problem is vibrations fm wheel section n not abt BBK since he has changed almost everything related to dat section!
So his major concern shd be...? (i cant answer bcos i'm not a mechanic)
救命啊 !!
我å±
我å±
why read? test it yourself... e-brake with OE brakes and BBK.EasternCanuck wrote:Nothing I have read, anywhere, indicates that bigger brakes will make you stop faster. The OP said his OEM brakes didn't stop him in time and he hit an Audi. I don't think BBK would make a diff in this instance.
