Car had already been scrapped there fore there isn't any body kit left.
This are the things which are removed before its been scrapped..
1) Invidia cat back exhaust - $1k (used for less den 1 year) (Reserved)
2) Hondata S300 - $700
3) BNIB miki type B railing driver side - $180
4) B16 engine whole block done up by reputable workshop high cam high com well balanced engine capable of hitting 240km/h on North south highway with correct gear ratio and capable to rev up to 9k RPM (not selling individually) - $2.5k
5) B16A stock bottom block - $400
6) B series gearbox with close ratio 345 straight cut 4.4FD and 1 way LSD all M Factory with all synchro replaced - $1K
7) Dc2 aluminium radiator used less den a year - $200
1998 ek4 sedan Carbon boot sprayed red color - $200
9) Type R intake manifold and throttle body - $200
10)Prelude brake kit with almost new brake pads - $250
If take item number 2,4,6,7 - $4K
Items stated above are the only item left
All item is located at workshop
Pls do not lowball
Pls do contact me at 8111919
