Honda Accord CM4/5 mainly (Stories, mods, meetups...)
Jnco
Post by Jnco » Tue Dec 03, 2013 2:34 pm
Thanks Bro. But do the checking is there any cost?
Fun Fun Fun.
Jnco
Post by Jnco » Wed Dec 04, 2013 2:56 am
maskedrider wrote:For both my car, either at KM or JB Honda agent
But JB is much cheaper and using orginal part
You can try at JB agent near the sentosa one which I visit them for regular service for my JB accord but SG one, I done most of the time at KM and sometimes at JB too
For suspension, do at JB agent which is 30-50% cheaper then KM, using same parts
Hope this can help to save cost for you
Bro jb sentosa there got Honda jb agent? Thanks
Fun Fun Fun.
AN
Re: 2nd hand cm5
Post by AN » Fri Jan 03, 2014 11:11 pm
junning wrote:Hi Zidane,
Welcome to this thread!
Have you bought it? The ad has expired.
Wondered what happened to the previous gearbox? Most of us don't have any problem. More important to have a test drive to feel the car. Common issues for Accord-CM are the steering wheel vibrations, leaky power steering hose.
Ever considered this facelift CM5
http://www.sgcarmart.com/used_cars/info ... 63&DL=1000
Normally what's the solution for steering whet vibrations?? Thanks in advance.
junning
Steering vibration
Post by junning » Sun Jan 05, 2014 2:55 pm
Hi AN,
One of the solution is to replace the worn engine mountings. But do still expect some slight steering wheel vibration.
This is an inherent problem for both Accord-CM and Accord-CP. But for the new Accord-CR with EPS, there isn't any steering wheel vibration.
Jnco
head light
Post by Jnco » Thu Jan 09, 2014 5:12 pm
Hi bro ,
i saw a few CM4/5 with front head light from hougang is totally different from my headlight. The light look like white hid line light which is very beautiful. where can i get it? any ideal? thanks
Fun Fun Fun.
junning
Accord-CM HID headlamp
Post by junning » Fri Jan 10, 2014 12:14 am
Hi Jnco,
Guess you're talkinging about these HID headlamps for CM5.
It's my favourite too, looks more sleek and it follows the bonnet shutline. Facelifted ones are dark chrome while pre-facelift are chrome. You can buy from local stockists.
Jnco
Re: Accord-CM HID headlamp
Post by Jnco » Fri Jan 10, 2014 12:36 pm
junning wrote:Hi Jnco,
Yes Yes junning. I refer to this headlight light. Nice. You know what the damage for the headlight?
Fun Fun Fun.
junning
Post by junning » Sat Jan 11, 2014 12:17 am
Hi Jnco,
You can give these stockists a call to check price & availability
http://www.minghee.com/contact.asp
http://www.autoparts.com.sg/thianseng
http://www.autoparts.com.sg/hexing
Jnco
HL
Post by Jnco » Sat Jan 11, 2014 11:50 am
i called them each side is around $200. haahaa.. over my budget. thanks junning.
Fun Fun Fun.
maskedrider
Re: HL
Post by maskedrider » Sun Jan 12, 2014 6:56 pm
Jnco wrote:i called them each side is around $200. haahaa.. over my budget. thanks junning.
You mean $200 each side full set with bulb?
Kyosho MP9 TKi OS V spec AKA tires Sanwa Blue thunder Spektrum
Jnco
Re: HL
Post by Jnco » Mon Jan 13, 2014 12:33 pm
i not sure it include the hid light. but is pretty ex. but the headlight is nice and neat.
Fun Fun Fun.
junning
Post by junning » Mon Jan 13, 2014 3:17 pm
Hi Jnco,
Believe the price quoted is for the housing only without bulb and ballast.
Jnco
Post by Jnco » Thu Jan 16, 2014 11:38 am
I saw alot at aliexpress.com but don.t know is the HD i want.
Btw, do your guy clean your CM throttle body? any recommend place. My rpm seens to drop abit already.
Fun Fun Fun.
junning
de-carbon
Post by junning » Mon Jan 20, 2014 11:10 pm
Hi Jnco,
I didn't clean mine previously, will be good to do de-carbonise.
But I did use this 3-in-1 at every oil change, you may give a try:
http://ows-germany.com/additives.php
http://www.sgcarmart.com/directory/list ... sed+Dealer
maskedrider
Gearbox shift light blow off
Post by maskedrider » Sat Feb 15, 2014 11:59 pm
Any advise what happen?
Suddenly my gearbox shifting lights blow off .... Totally black out
The P R N D D1 D2 ... Not at the speedo meter there ya
