INTAKE + CAMS + ECU
- DIY CAI - remove resonator & use Alu piping to stock airbox.: $50-$80/- : Anywhere
- K&N Panel Filter element : $80 -$90 : Many Shops
- Spoon Panel Filter Element : $120 : Mikotai
- Mugen Carbon Intake Kit : $1.5kplus : SI, GMS, MR
- Gruppe M Intake Kit : $1.2k: SI, : MR
- HKS Intake Kit : $310 : GR
- K&N Cone in stock air box : $150 :MW, AD
- Apexi SRI : $370+ : AD
- Cyberspeed CAI: $?? :
- BMC CDA: $550++ : Espace
- Spoon venturi throttle body: swap + $550 : mikotai
- Toda Cam spec A include installation : $3100 : ST ,MR
- Skunk 2 Cam Shafts : $ MW
- Skunk 2 Valve Springs : $ MW
- Skunk 2 Ti Retainers : $ MW
- HKS F-CON SZ with cable harness & tuning: $2650 : GR
- HKS F con V Pro: $5.4k : GR
- Hondata & Tune $2k+ : Max
- HKS Oil Cooler Kit : $0.8k+ : GR
- Universal 11/14/19 row Oil Cooler kit - $350 SI(DX)
- KDK fan : priceless
- Spoon ECU - $1.7k SG
- Spoon Final Drive 5.1 - $520 SG
- Mugen CF air intake kit - $1.4k SG
2) EXHAUST + HEADER
- Js Racing Titanium (LTA approved) : $1980 : GR
- [HKS Silent Hi-power (LTA approved): $1600 : GR , $1.4k+ :YB
- Fujitsubo Legalise R (LTA approved): $1.5kplus : ST , $1.3k+ : YB
- Mugen Catback (LTA approved): $ 2600 MR, SI/ MR
- Amuse Titanium : $ 3000+ :SI
- Spoon 4-2 extractor $1200, mikotai
- Toda 4-2-1 CL7 header - $1930
- Six Sigma Racing (USA) custom CL7 header: $2k+ : SI - contact d_iceman for details.
- Mugen 4-2-1 Header + hi-flow Cat: 3k+ SI/ MR
- Spoon Engine Head & Gasket: 0.7k+ :mikotai
- Spoon Carbon Kevlar Spark Plug Cover : $180+ : Mikotai
3) SUSPENSION KITS & BRAKES
- HKS Hypermax III : $3000 : GR
- TEIN Flex : $2000 : GR, ST, Choon
- TEIN Mono Flex: $2400 : GR
- TEIN Super Street : $1400 : GR, ST
- TEIN EFDC : $ : 600+
- Tein S.Tech spring : $400 : LS
- BC coilover: $1200: RT
- Tomei (yap) coilovers : $980 : YB
- Tomei N1 Coilover : $1450 : YB
- Mugen : $2.5k to 2.6k , SI
- Mugen 5adj suspension - $2.6k : MR
- Aragosta coilovers : $3.6k -4K : SI
- Spoon Coilovers : $4K : SI/Mikotai
- Toda Fightex Coilovers: $3K+ : MR
- Honda access sport 5 way adjustable: ??
- Koni adjustable yellow dampers + eibach prokit : $1.2k?
- Koni Adj. Yellow Damper (CL7/CM5) : $600
- Buddy Club racing spec damper 15way adj: $??? :
- KW coilvers variant 1 : $2k
- Bilstein b12 kit : $1.5k : TSPL
- Springs Espliers : $370
- Springs Eibach : $600 :Espace
- Springs Team Kunimitsu : $650 :LA
- Spoon Calipers : $2600plus :GR,ST :
- AP 4pot +330mm 2pc rotor+550deg pads+hoses : $3288 MW (limited offer)
- AP 6 pot Calipers : $4688 MW ( limited offer)
- Exzess 4 pot+330mm 2pc rotor+550deg pads+hoses : $2888 MW (promo over)
- Brembo 4pot GT Kit : $POA MW
- Project Mu 4 Pot : $3500 SI
- Steel Braided Brake Hose : $280 YB : APP $350 a set : Exzess $288 MW
- Brake Pads : Project Mu $120-180; Endless: $250, Feels $350, Mugen $350 +
- Endless 6 Pot Calipers with rotor: $5500 : GR; Panaracer: $5200
- Dephi brake pads 50-850c : front and back with labour $750
- Wilwood 4pot FSL front + SS Hose, 2pc rotors & EBC Front/Rear Pads :$2.8k : PJ
- Espec 4 pot : $1850 : LT
- JBT 4 pot + 2 pc rotors: $2.8k : YB
- Alcon 4 pot + 2pc rotors + SBH: $4k +: MR
- Spoon coilovers - $3k - SG
- Spoon brake kit - $2.6K - SG
- Cusco coilovers - $2.2k - $2.4k: MW
- Spoon brake kit (320mm)- $3K - YB
4) ELECTRONICS & GADGETS
- Apexi RSM + Stand : $350-400+ : ST, GT, YB - Apexi Versa Cruise : $310 : ST
- Apexi NA timer : $180plus : Many Shops
- Apexi AFC NEO : $700+ Tune $180 : ST
- Pivot Voltage Stabiliser : $160 : MW : $85 : PL
- Pivot SuperEarth G-Cables (Silver type) : $120plus : NG
- Pivot Ign Spark : $128 MW
- Pivot Ign Earth : $78 MW
- Max Power (Magnets) : $?? : Many shops
- Defi Gauges for 3 meters plus controller: $1.1k ST, TC
- Mugen Thermostat, fan switch & Rad Cap + oem coolant : $400plus : MW
- Cairefresh Hepa Aircon Filter : $41 : Jimbo
- HKS Circle Earthing : $315 : GR, K'sW
- VAFC2 : GT Auto
- Buddy Club Spec Condenser ; $260+ SI
- Pivot Shift Light (small one) $120 GT
- Coil Amp : $300 Gary Engineering (Paya Ubi)
5) TIRES & RIMS
- Volk Racing : 17" $2560-3200 YB, LS, GR, Stamford
- Advan RS: 17" $500 - 560. YB, LS, TH
- 17" x8JJ +40 [7.9Kgs] OZ Ultraleggra: $380-430
- BBS [8.2kg P/R : $280plus : MHTS
- Prodrive GC010 17*7.5 : $2600 :SE 18' 18x8.0 $3000 (1 set)
- Bridgestone RE050 : $250 SE $220 CC
- Bridgestone GIII [215/45/17] : $230 : MHTS
- Bridgestone SO3 : $235 LS
- Toyo V-mode [215/45/17] [comfort base] : $200 : MHTS
- Falken ST 215 Semi : $195/pc : PH
- BF Goodrich : $ :
- Yokohama AD07 [215/45/17] : $190/pc : PH, YB
- Pirelli P-Zero Nero : $300 LS
- STP Son of a Gun all purpose cleaner - Fantastic for tyres $12.80
- goodyear eagle f1: $170
- michelin preceda (very quiet tyres) : $200
- Prodrive GC010E 17*8 : $2400; PH
- Works Wheel Nut $130 LS
- SSR 18 x 7.5 - $2400 : YB
- VR RE30 18 X 8 $3.2K - LS
6) STRUT/SWAY BARS & OTHER
- Cusco strut bar: $248 :MW
- Mugen : $ :
- Phase Carbon Fibre ; $ :
- Feels Front Strut Bar : $300+ MR
- Feel Front Carbon Strut Bar : $500+ MR
- Spoon Front Strut Bar : $260 Mikotai
- Spoon Engine Damper : $300++ MR/ST
- Comptech Rear Sway Bar $260: SI
- SPC Camber Kit for rear - $430 include alightment RV
- Feel's engine torque damper: $360 MR
- cusco front lower bar : $130 MW
- Spoon Short Shifter : $500 ST
- Neuspeed Short shifter : $110 SI
- Mugen Short Shifter : $295 YB
- Spoon Front Camber Kit: $800+ Mikotai
- Feels Steel Braided Clutch Hose : $200 SI/MR
- Feels Steel Braided Brake Hose Set : $380 : MR
- Team Kunimitsu Front & Rear Sway Bar : $800+ No install LA
- Swift Stabilizer (Tohatsu) Fornt % Rear Bar: $U/K YB
http://www.tohatsu-springs.co.jp/stabil ... _main.html)
- Maximum Velocity crang pulley : $288 MW
- Silver's Engine Torque Damper : $ 168 MW
- SuperPro Poly Bushing (rear): $300 TL
- J's Racing front strut bar : $290 YB
- Spoon Engine Damper - $260 SG
- Spoon tower strut bar - $250 SG
- J's Racing Rear Camber Kit - S$400 MR
7) BODY KITS, LUBS & ANYTHING
- Mugen Grill : $450 : LT
- Mugen Front Bumper + Lower Air Dam : $ :
- Mugen 06' Full Bodykiy : 3k++ (Unpainted) MR
- BMW Rear Lip Spoiler : $250
- Spoon Duck Tail Spolier : $520 mikotai
- Spoon DCF Bonnet :$1,600~1800 SI
- OEM MTF-II : $55 : TS
- Amsoil 1 Carton 12 Quants : $180
- Mugen VT Pro 4l : $140
- HKS Super NA : $128 include filter and oil change GR
- HKS Spark Plug: $112 for set of 4
- Spoon Sock for brake fluid holder and steering: $28 ST
- Colgan Car Bra $350 SI
- Mugen VISOR $240 YB
- 'Chiong' Mugen Visor $100 Skull(PM)
- Ducarto Ground effector : $200 SI / YB
- NGK Sparkies [IFR7G-11KS] : $85~$90 for set of 4 :SI
- "CC Type" BJ Wiper Blades : $31 CC-SI
- Bride GIAS Sports $1750 (include seat rail,walk in price) ST
- Bride Vios full bucket seat $1360 (with Bride FO type seat rails) ST
- Bride GIAS $2100 to ??? (include seat rail) SI,ST,MR & Others
- Spoon Reservoir cover - $20 SG
- Mugen Reservoir cover - $22 SG
- Spoon Boot spoiler - $500 SG
- Spoon/Phase Front bumper - $1.8k SG
- Spoon DCF Bonnet - $1.6k SG
- Broquet Boost Master 50 - $700 - $750 Merlin (amk autopoint)
- Full Alu Radiator - $480 - SI(DX)
- Silicone Radiator Hose - $175 - SI(DX)
Key for sellers/workshops - tel numbers checked as of Apr 1 2006.
SI - self-import or group buy
AD - AutoDynamac - 6745 9702
CC - Chang Choon tyre & battery 68415393
GMS - Gan Motorsports - 6753 4404
GR - Garage R - 6554 4840
GT - GT Auto Sound - 6280 6636
LS - Leong Seng - 6744 4280
MR - Maximus Racing - 9856-9774
MW - McWell - 68444640
NG - New Generation - 6348 6220
PH - Poh Heng - 6456-3344
PL - Poh Lay - 6475 1990
RV - Riverview - 6481 2025 or 6481 5797
RT - Race Tech
ST - ST Powered - 6282 0330
TC - Toycar garage -
TH - Tai Huat - Ah Chuan 64537205
TS - Thian Seng (waterloo) - 3371795, 3369777
TSPL - Tye Soon Pte Ltd - 92772411 (justin)
YB - Yap Bros - 6841 2255
PJ - PhantomGT aka Johnny - 96687580
Mikotai aka Michael - 96902969
TL - Tan Lim Motors - Contact Alec 96860676
SG - steve - 96721076
Pana- 96950016
DX - DX-Performance - David Tan - 91016626
