CL Poison Guide (280605)
bethany
Re: Euro R
Post by bethany » Wed Aug 22, 2007 4:51 pm
coldspark wrote:Anybody driving it and which PI do you recommend? i am thinking of WOW and Frankel....
I was referred by Stamford Tyres Retail Sales Manager to look for Frankel but i din go... i went TurfCity instead..
When there is a will, there is a way
trd_rg
Post by trd_rg » Wed Aug 29, 2007 9:23 am
INTAKE + CAMS + ECU
- DIY CAI - remove resonator & use Alu piping to stock airbox.: $50-$80/- : Anywhere
- K&N Panel Filter element : $80 -$90 : Many Shops
- Spoon Panel Filter Element : $120 : Mikotai
- Mugen Carbon Intake Kit : $1.5kplus : SI, GMS, MR
- Gruppe M Intake Kit : $1.2k: SI, : MR
- HKS Intake Kit : $310 : GR
- K&N Cone in stock air box : $150 :MW, AD
- Apexi SRI : $370+ : AD
- Cyberspeed CAI: $?? :
- BMC CDA: $550++ : Espace
- Spoon venturi throttle body: swap + $550 : mikotai
- Toda Cam spec A include installation : $3100 : ST ,MR
- Skunk 2 Cam Shafts : $ MW
- Skunk 2 Valve Springs : $ MW
- Skunk 2 Ti Retainers : $ MW
- HKS F-CON SZ with cable harness & tuning: $2650 : GR
- HKS F con V Pro: $5.4k : GR
- Hondata & Tune $2k+ : Max
- HKS Oil Cooler Kit : $0.8k+ : GR
- KDK fan : priceless
- Spoon ECU - $1.7k SG
- Spoon Final Drive 5.1 - $520 SG
- Mugen CF air intake kit - $1.4k SG
2) EXHAUST + HEADER
- [HKS Silent Hi-power (LTA approved): $1600 : GR , $1.4k+ :YB
- Fujitsubo Legalise R (LTA approved): $1.5kplus : ST , $1.3k+ : YB
- Mugen Catback (LTA approved): $ 2600 MR, SI/ MR
- Amuse Titanium : $ 3000+ :SI
- Spoon 4-2 extractor $1200, mikotai
- Toda 4-2-1 CL7 header - $1930
- Six Sigma Racing (USA) custom CL7 header: $2k+ : SI - contact d_iceman for details.
- Mugen 4-2-1 Header + hi-flow Cat: 3k+ SI/ MR
- Spoon Engine Head & Gasket: 0.7k+ :mikotai
- Spoon Carbon Kevlar Spark Plug Cover : $180+ : Mikotai
3) SUSPENSION KITS & BRAKES
- TEIN Flex : $2000 : GR, ST, Choon
- TEIN Mono Flex: $2400 : GR
- TEIN Super Street : $1400 : GR, ST
- TEIN EFDC : $ : 600+
- Tein S.Tech spring : $400 : LS
- BC coilover: $1200: RT
- Tomei (yap) coilovers : $980 : YB
- Tomei N1 Coilover : $1450 : YB
- Mugen : $2.5k to 2.6k , SI
- Mugen 5adj suspension - $2.6k : MR
- Aragosta coilovers : $3.6k -4K : SI
- Spoon Coilovers : $4K : SI/Mikotai
- Toda Fightex Coilovers: $3K+ : MR
- Honda access sport 5 way adjustable: ??
- Koni adjustable yellow dampers + eibach prokit : $1.2k?
- Koni Adj. Yellow Damper (CL7/CM5) : $600
- Buddy Club racing spec damper 15way adj: $??? :
- KW coilvers variant 1 : $2k
- Bilstein b12 kit : $1.5k : TSPL
- Springs Espliers : $370
- Springs Eibach : $600 :Espace
- Springs Team Kunimitsu : $650 :LA
- Spoon Calipers : $2600plus :GR,ST :
- AP 4pot +330mm 2pc rotor+550deg pads+hoses : $3288 MW (limited offer)
- AP 6 pot Calipers : $4688 MW ( limited offer)
- Exzess 4 pot+330mm 2pc rotor+550deg pads+hoses : $2888 MW (promo over)
- Brembo 4pot GT Kit : $POA MW
- Project Mu 4 Pot : $3500 SI
- Steel Braided Brake Hose : $280 YB : APP $350 a set : Exzess $288 MW
- Brake Pads : Project Mu $120-180; Endless: $250, Feels $350, Mugen $350 +
- Endless 6 Pot Calipers with rotor: $5500 : GR; Panaracer: $5200
- Dephi brake pads 50-850c : front and back with labour $750
- Wilwood 4pot FSL front + SS Hose, 2pc rotors & EBC Front/Rear Pads :$2.8k : PJ
- Espec 4 pot : $1850 : LT
- JBT 4 pot + 2 pc rotors: $2.8k : YB
- Alcon 4 pot + 2pc rotors + SBH: $4k +: MR
- Spoon coilovers - $3k - SG
- Spoon brake kit - $2.6K - SG
4) ELECTRONICS & GADGETS
- Apexi RSM + Stand : $350-400+ : ST, GT, YB - Apexi Versa Cruise : $310 : ST
- Apexi NA timer : $180plus : Many Shops
- Apexi AFC NEO : $700+ Tune $180 : ST
- Pivot Voltage Stabiliser : $160 : MW : $85 : PL
- Pivot SuperEarth G-Cables (Silver type) : $120plus : NG
- Pivot Ign Spark : $128 MW
- Pivot Ign Earth : $78 MW
- Max Power (Magnets) : $?? : Many shops
- Defi Gauges for 3 meters plus controller: $1.1k ST, TC
- Mugen Thermostat, fan switch & Rad Cap + oem coolant : $400plus : MW
- Cairefresh Hepa Aircon Filter : $41 : Jimbo
- HKS Circle Earthing : $315 : GR, K'sW
- VAFC2 : GT Auto
- Buddy Club Spec Condenser ; $260+ SI
- Pivot Shift Light (small one) $120 GT
5) TIRES & RIMS
a) Volk Racing : 17" $2560-3200 YB, LS, GR, Stamford
b) 17" x8JJ +40 [7.9Kgs] OZ Ultraleggra: $380-430
c) BBS [8.2kg P/R : $280plus : MHTS
d) Prodrive GC010 17*7.5 : $2600 :SE 18' 18x8.0 $3000 (1 set)
e) Bridgestone RE050 : $250 SE $220 CC
f) Bridgestone GIII [215/45/17] : $230 : MHTS
g) Bridgestone SO3 : $235 LS
h) Toyo V-mode [215/45/17] [comfort base] : $200 : MHTS
i) Falken ST 215 Semi : $195/pc : PH
j) BF Goodrich : $ :
k) Yokohama AD07 [215/45/17] : $190/pc : PH, YB
l) Pirelli P-Zero Nero : $300 LS
m) STP Son of a Gun all purpose cleaner - Fantastic for tyres $12.80
n) goodyear eagle f1: $170
o) michelin preceda (very quiet tyres) : $200
p) Prodrive GC010E 17*8 : $2400; PH
- Works Wheel Nut $130 LS
6) STRUT/SWAY BARS & OTHER
- Cusco strut bar: $248 :MW
- Mugen : $ :
- Phase Carbon Fibre ; $ :
- Feels Front Strut Bar : $300+ MR
- Feel Front Carbon Strut Bar : $500+ MR
- Spoon Front Strut Bar : $260 Mikotai
- Spoon Engine Damper : $300++ MR/ST
- Comptech Rear Sway Bar $260: SI
- SPC Camber Kit for rear - $430 include alightment RV
- Feel's engine torque damper: $360 MR
- cusco front lower bar : $130 MW
- Spoon Short Shifter : $500 ST
- Neuspeed Short shifter : $110 SI
- Mugen Short Shifter : $295 YB
- Spoon Front Camber Kit: $800+ Mikotai
- Feels Steel Braided Clutch Hose : $200 SI/MR
- Feels Steel Braided Brake Hose Set : $380 : MR
- Team Kunimitsu Front & Rear Sway Bar : $800+ No install LA
- Swift Stabilizer (Tohatsu) Fornt % Rear Bar: $U/K YB
(http://www.tohatsu-springs.co.jp/stabil ... _main.html)
- Maximum Velocity crang pulley : $288 MW
- Silver's Engine Torque Damper : $ 168 MW
- SuperPro Poly Bushing (rear): $300 TL
- J's Racing front strut bar : $290 YB
- Spoon Engine Damper - $260 SG
- Spoon tower strut bar - $250 SG
- J's Racing Rear Camber Kit - S$400 MR
7) BODY KITS, LUBS & ANYTHING
- Mugen Grill : $450 : LT
- Mugen Front Bumper + Lower Air Dam : $ :
- Mugen 06' Full Bodykiy : 3k++ (Unpainted) MR
- BMW Rear Lip Spoiler : $250
- Spoon Duck Tail Spolier : $520 mikotai
- Spoon DCF Bonnet :$1,600~1800 SI
- OEM MTF-II : $55 : TS
- Amsoil 1 Carton 12 Quants : $180
- Mugen VT Pro 4l : $140
- HKS Super NA : $128 include filter and oil change GR
- HKS Spark Plug: $112 for set of 4
- Spoon Sock for brake fluid holder and steering: $28 ST
- Colgan Car Bra $350 SI
- Mugen VISOR $240 YB
- 'Chiong' Mugen Visor $100 Skull(PM)
- Ducarto Ground effector : $200 SI / YB
- NGK Sparkies [IFR7G-11KS] : $85~$90 for set of 4 :SI
- "CC Type" BJ Wiper Blades : $31 CC-SI
- Bride GIAS Sports $1750 (include seat rail,walk in price) ST
- Bride Vios full bucket seat $1360 (with Bride FO type seat rails) ST
- Bride GIAS $2100 to ??? (include seat rail) SI,ST,MR & Others
- Spoon Reservoir cover - $20 SG
- Mugen Reservoir cover - $22 SG
- Spoon Boot spoiler - $500 SG
- Spoon/Phase Front bumper - $1.8k SG
- Spoon DCF Bonnet - $1.6k SG
Key for sellers/workshops - tel numbers checked as of Apr 1 2006.
SI - self-import or group buy
AD - AutoDynamac - 6745 9702
CC - Chang Choon tyre & battery 68415393
GMS - Gan Motorsports - 6753 4404
GR - Garage R - 6554 4840
GT - GT Auto Sound - 6280 6636
LS - Leong Seng - 6744 4280
MR - Maximus Racing - 9856-9774
MW - McWell - 68444640
NG - New Generation - 6348 6220
PH - Poh Heng - 6456-3344
PL - Poh Lay - 6475 1990
RV - Riverview - 6481 2025 or 6481 5797
RT - Race Tech
ST - ST Powered - 6282 0330
TC - Toycar garage -
TS - Thian Seng (waterloo) - 3371795, 3369777
TSPL - Tye Soon Pte Ltd - 92772411 (justin)
YB - Yap Bros - 6841 2255
PJ - PhantomGT aka Johnny - 96687580
Mikotai aka Michael - 96902969
TL - Tan Lim Motors - Contact Alec 96860676
SG - steve - 96721076
Pana- 96950016
CyberWhite
Post by CyberWhite » Thu Aug 30, 2007 5:51 pm
trd_rg wrote:INTAKE + CAMS + ECU
2) EXHAUST + HEADER
- Cusco coilovers - $2.2k - $2.4k: MW
- VAFC2 : GT Auto
5) TIRES & RIMS
- Mugen : $ :
RT - Race Tech
Pana- 96950016
free2d
Post by free2d » Sat Sep 22, 2007 1:07 am
Got anyone using the Project Mu Slim?
How much and where to get it.
Thanks.
svperstar
Post by svperstar » Sat Sep 22, 2007 2:24 am
free2d wrote:Got anyone using the Project Mu Slim?
Thanks.
bro this is a wts folder......i suggest posting your questions on the main accord forum...i think you will get more answers there.... :lol:
BakerQbal
Post by BakerQbal » Tue Sep 25, 2007 6:14 pm
Anyone can advice which exos is legal for use in CL7A? It seems like most after market exos is meant for CL7R only..
ebot
silver spark plug
Post by ebot » Tue Sep 25, 2007 10:08 pm
hey bros, do u know how much is the nology silver spark plug for CL7?
pReTeNd3R
Post by pReTeNd3R » Tue Oct 02, 2007 4:26 pm
Guys,
haven been seeing so many strut bars laterly.
Actually, what are the bars needed & the purpose of the bars for a CL7A?
Front strut bar?
Rear Strut bar?
Anti roll bar?
Ungercarraige bar?
Very confusing leh :? :?
aXewYeZee
Post by aXewYeZee » Tue Oct 02, 2007 4:37 pm
pReTeNd3R wrote:Guys,
Front strut bar? - To provide better handling mainly when cornering.
Rear Strut bar? - To provide better handling mainly when cornering.
Anti roll bar? - To hold your tyres (got both front & rear anti-roll bars) as much as possible to the ground when cornering, so more stable, thus better handling. These are fitted below whereas strut bars are fitted in the engine compartment and in the boot.
Undercarraige bar? - Also kown as lower arm bar. To reduce flex of your car chasis. Most cars can be divided to 3 sections, front, middle and rear.
Loud Pipe Saves Lives
pReTeNd3R
Post by pReTeNd3R » Tue Oct 02, 2007 4:45 pm
Wow bro, thanx for wonderful explanation. So where can i get all these bars? MR?
Which brand is better? Ant recommandation?
aXewYeZee
Post by aXewYeZee » Tue Oct 02, 2007 5:01 pm
There is Cusco, Alutec, Summit, Ultra Racing, I also heard of one chao ti with Mugen stickers on... :lol:
Which brand is better? Each to his own I guess. Not right to comment on such...
Well, MR is one option... Lots of bros will recommend MR. Most probably will meet some bros there and get poisoned by them... :lol: :lol:
There other workshops around, say in AMK Autopoint.
Alternatively, you can wait for my Ultra Racing bars to arrive and have a look and test...
Hope this helps.
Cheers! :lol:
pReTeNd3R
Post by pReTeNd3R » Tue Oct 02, 2007 5:13 pm
Hope this helps.
Cheers! :lol:
Oh ok. thanx for your advice bro, will go there see see look look. :D :D
stevegoh
UPdated PRices - 22 OCT 07
Post by stevegoh » Mon Oct 22, 2007 12:19 pm
INTAKE + CAMS + ECU
- Spoon Final Drive 5.1 - $550 SG - Mugen CF air intake kit - $1.4k SG
2) EXHAUST + HEADER
- Spoon coilovers - $2.8k - SG
- Spoon brake kit + brake hose - $2.6K - SG
- cusco zero-2E coilovers - $2-2.1k - SG
- mugen rotors - $480 - SG
- mugen pads - $350 - SG
- VAFC2 : GT Auto
- Defi NA package 3 meters - $920 - SG
5) TIRES & RIMS
- Mugen : $ :
- Mugen Reservoir cover - $25 SG
- Spoon/Phase Front bumper - $1.6k SG
RT - Race Tech
Pana- 96950016
spitfire
Post by spitfire » Mon Oct 22, 2007 12:28 pm
twinx72 wrote:INTAKE
a) DIY CAI
[Remove Stock Resonator & Use Alu Intake : $50-$80/- : Anywhere
b) K&N Panel Filter element : $80 -$90/- : Many Shops
c) Mugen Carbon Intake Kit : $1.4kplus : SI, GMS,
d) GruppeM Intake Kit : $1.35k: SI, :
e) HKS Intake Kit : $310 : GR
f) K&N Cone in stock air box : $150 :MW, AD
g) Apexi SRI : $370+ : AD
h)Phase Throttle Body - 1 to 1 swap plus $450
i) Spoon TB - swap + $350
j) Cyberspeed Intake - $260 (AD, Jeep Chee, Yap, Juzz4Cars, Lim Tan)
k) Boring of TB - $160 ( Gary's Engeering)
l) Blitz Sonic Air Intake ( Diesel_power)
m) BMC DCA air filter : (Espace 67483430)
Apparently, this owner took out his Mugen air intake to replace the BMC CDA.
2) EXHAUST
a) Apexi : $ : ST (No hope)
b) HKS : $1650 : GR (LEGAL)
c) FK Special Mod : $ : FK
d) Fujitsubo legalise : $1.3kplus : SI [Semi Group-B]
e) Mugen : $ 3000
f) Phase : $ :
g) Amuse Titanium : $ 3000+ :SI
h) Phase manifold 4-1 : $ :
i) Toda Cam spec A include installation : $3100 ST
j) Toda 4-2-1 CL7 manifold - $1930 no installation
a) TEIN Flex : $2000 : GR, ST, Choon
b) TEIN Super Street : $1400 : GR, ST
c) Mugen 5way/Adj Fix/Ht.: $2400+
d) TEIN EFDC : $ : 600+
e) Springs Eplisers : $370
f) Spoon Calipers : $2600plus :GR,ST :
g) AP 6 pot Calipers : $4800
h) Steel Brake Hose : $ : APP $350 a set
i) Brake Pads : Project Mu $120-180; Endless: $250
j) Endless 6 Pot Calipers with rotor: $5500
k) honda access sport 5 way adjustable
l) koni adjustable yellow dampers + eibach prokit : $1.2k?
m) buddy club racing spec damper 15way adj
n) KW coilovers : $2200 without Installation
o) bilstein btc kit : $1.5k?
p) Dephi brake pads 50-850c : front and back with labour $750
q) Aragosta 9kg,4.8kg : $3k?
r) Mugen SBH : $400+
s) Toda FIGHTEX Coilovers F:8k, R:6k. (diesel_power)
a) Apexi RSM + Stand : $400plus : ST, GT Auto (Better workmanship)
b) Apexi Versa Cruise : $310 : ST, GT Auto (Better workmanship)
c) Apexi NA timer : $180plus : Many Shops
d) Pivot Voltage Stabilisers : $100 : Many Shops + wana Be
e) Pivot SuperEarth G-Cables (Silver type) : $120plus : NG
f) Max Power (Magnet) : $ : Many shops
g) Defi Gauges : $1050-1300 for 3 meter plus controller
h) Mugen Thermostat, fan switch & Rad Cap + oem coolant : $400plus : MW
i) Hepa Aircon Filter : $48]
j) HKS Circle Earthing : $315 : GR, K'sW
k) HKS F-CON SZ with cable harness & tuning: $2650 GR
l) VAFC2 : GT Auto
m) Buddy Club Spec Condenser ; $260+ SI
5) TIRES & RIMS
b) OZ : $300-350 LS
j) BF Goodrich : Abt $150/ pc PH
p)Bridgestone GIII [225/40/R18] : $300 : Tai Huat
q) Work Emotions CR Kai 18" : $530 / rim Tai Huat
r) BuddyClub PII Racing 18X8 +45: No more in production
s) Bridgestone SO2 [225/40/18]: $300+, SouthEast Tyre
a) Cusco : $248 :MW
b) Mugen : $ :
c) Phase Carbon Fibre ; $ :
d) Comtech Rear Sway Bar $260: SI
e) Camber Kit for rear - $430 include alightment RV
f) Phase short shifter - 1 to 1 swap plus $280
g) cusco front lower bar : $130 MW
h) Spoon Short Shifter : $500 ST
i) neuspeed Short shifter : $110 SI
j) Cusco 4 point Lower bar : $260
k) Mugen shift Knob : $160 YB
l) FEELS' Strut Bar alum : $256 YB
a) Mugen Grill : $450 : LT
b) Mugen bodykit (front,side,rear) = $3.6K + (Lion auto)
c) BMW Rear Lip Spoiler : $ :
d) OEM MTF-II : $ : SI [Group Buy]
e) Amsoil 1 Carton 12 Quants : $180
f) Mugen VT Pro 4l : $140
g) HKS Super NA : $128 include filter and oil change GR
h) HKS Spark Plug: $112 for set of 4
i) Spoon Sock for brake fluid holder and steering: $28 ST
j) Phase Rear Spoiler $250
k) Pivot Shift Light (small one) $120 GT
L) Colgan Car Bra $350 SI
M) Works Wheel Nut $130 LS
N) Mugen VISOR $240 YB
O) 5,46, 5,83 & 6.33 final drives $1700 from D_Iceman
P) Mugen MT105 engine treatment oil - $95
Q)RAYS lock nut: $180 Stamford
Engine and related parts
a. Toda Spec A2 camshafts, include installation (diesel_power)
toda racing exhaust manifold available too.
b. Toda Lightened Flywheel Clutch kit (diesel_power)[/quote]
Bro, I am a little bit more conservative and just want to pump the 160hp to 180hp without the loudness, meaning no exhaust.
New to mods on the Accord so would need any advice. What does the HKS intake kit does? And Voltage stabilizerS>?
Actually got a friend who owns the 2.4 JDM in Australia and he pushes out about 190hp stock. Would the CL7A 2.0 be able to handle this kind of power without changing brakes, etc?
BakerQbal
Post by BakerQbal » Fri Oct 26, 2007 12:48 pm
BakerQbal wrote:Anyone can advice which exos is legal for use in CL7A? It seems like most after market exos is meant for CL7R only..
Anyone can reply me this question? New to CL7A and would like to find out more.
Thanks in advance
