Dear all,
I am having problems with my brakes recently, it tends to vibrate a lot when I step on it especially from high speed to lower speed.
I used to have this problem but when I changed my brake pads, the issue went away.
Now after 1 year, the problem is back again. I suspect it is the disc rotor that is warped.
I would to ask for advise if anyone knows whether I should have the disc skimmed or change the disc rotor?
If I were to change, anyone can advise where to get the original disc rotors and how much will it costs?
Vibrating steering wheel when braking
Skim?
Purist would tell you not to skim for safety reason. Skimming was not intended by manufacturer.
However if you wish to save cost you can ask yr mechanic to assess if skimming can be carried out looking at yr brake disc condition.
- XiaoNick
- 9000rpm Rev Cut
Re: Vibrating steering wheel when braking
Disk rotor warp. Get new rotors.sililo wrote:Dear all,
Normally its not warp rotor. Its obvious it is not warp rotor when the problem goes away when you change pads. Check out the article for more info.
http://www.race-essentials.com/vibrations_under_braking
