Anyone know what to check if cl7a FC is 410km full tank
jmart537
Post by jmart537 » Sun Oct 13, 2013 3:12 pm
Hi all
Fuel filter
Oil filter
Spark plug
Air filter
All replaced new
Engine oil change
Yet fuel consumption is still very low 410 km til mark E. Boot nothing inside.
Please suggest what to do next
Teow Yiwei
Post by Teow Yiwei » Sun Oct 13, 2013 8:54 pm
Tyre pressure and wheel alignment
Right foot
jmart537
Post by jmart537 » Sun Oct 13, 2013 11:00 pm
Both done
speedsterdarren
Post by speedsterdarren » Mon Oct 14, 2013 12:22 am
Try downsizing your wheel size bro 8)
2cubed
Post by 2cubed » Mon Oct 14, 2013 2:43 am
If this is mainly city driving then its normal.
Teow Yiwei
Post by Teow Yiwei » Mon Oct 14, 2013 3:30 pm
you may wish to change to another brand of petrol or ron. it sometimes works. or reset ecu?
jmart537
Post by jmart537 » Mon Oct 14, 2013 9:30 pm
Teow Yiwei wrote:you may wish to change to another brand of petrol or ron. it sometimes works. or reset ecu?
Yes will try this and monitor
redhonda
Post by redhonda » Wed Oct 16, 2013 8:49 pm
maybe can try .
1. air-con
2. belt
3. tensioner
4. gear oil
5. tb clean
6. exhaust check for any loose.
jmart537
Post by jmart537 » Thu Oct 17, 2013 8:14 am
Atf oil change
Reset ecu.
Change to high octane from 95 to 98
Monitor again
jmart537
Post by jmart537 » Sun Oct 20, 2013 8:31 am
Hi all.
Thanks. After reset it is back to normal.
Accord515
Post by Accord515 » Mon Oct 21, 2013 10:05 pm
Check your exhaust, is it leaking ?
Teow Yiwei
Post by Teow Yiwei » Tue Oct 22, 2013 8:01 am
you reset ecu and fc improves?
jmart537
Post by jmart537 » Tue Oct 22, 2013 11:08 pm
Yes it improves after resetting
jmart537
Post by jmart537 » Tue Oct 22, 2013 11:09 pm
The exos is not leaking, ask to check carefully
Slayer08
Re: Anyone know what to check if cl7a FC is 410km full tank
Post by Slayer08 » Sat May 10, 2014 3:00 pm
jmart537 wrote:Hi all
Fuel filter
Oil filter
Spark plug
Air filter
All replaced new
Engine oil change
Hi.. Mine barely reaches 400km before amber lite on.. FC is 7km plus per litre..2nd hand car.. so must tune the ecu? roughly how much pls?
