rjj
Post
by rjj » Sun Sep 11, 2011 9:56 pm
PaPa_H wrote:Bro rjj,
Wat's the damage for unchip tuning? Can it shift the v-tec earlier like 3-3.5k rpm cos I rarely past 4k rpm.
Bro if you installed from Alex, he should give you sound advise as he tune quite a handful ODY....
to share my experience by shifting the V-tec doesnt really help, furthermore our is Ivtec....which mean it open up accordingly to RPM if i remember correctly.
improvement is very little even with aft market air filter with mugen exo....the gain was about 7-10bhp if i remember correctly....
the highest NA ODY was dyno 280bhp.......the ride is still running around and the owner is also a member here but hardly login liow.....
cheers
prodi9y
Post
by prodi9y » Sun Sep 11, 2011 11:37 pm
280bhp for NA is darn lots of hardwork siah. Base model is KM or Abs?
rjj
Post
by rjj » Mon Sep 12, 2011 1:20 am
prodi9y wrote:280bhp for NA is darn lots of hardwork siah. Base model is KM or Abs?
KM
PaPa_H
Post
by PaPa_H » Mon Sep 12, 2011 10:19 pm
Odc maniac wrote:PaPa_H wrote:
Thanks bro...I have installed it yesterday
As for the so-call increase in power, I was told it breakdown the fuel molecules for better combustion efficiency...so hopefully can 'improve' my mileages
Bro, pls update the result
Haha...will do bro
I dont expect miracle but +1km/l improvement am happy already
PaPa_H
Post
by PaPa_H » Mon Sep 12, 2011 10:23 pm
rjj wrote:PaPa_H wrote:Bro rjj,
cheers
NA engine @ 280bhp!!! I am amazed bro...
Sigh...still thinking tuning can improve my torque or activate i-vtec @ earlier rpm...
PaPa_H
Post
by PaPa_H » Mon Sep 12, 2011 10:29 pm
Bro rjj,
Any advice on improved handling? Am thinking of installing a front strut bar...
Odc maniac
Post
by Odc maniac » Mon Sep 12, 2011 10:44 pm
My opinion, coilover bro
rjj
Post
by rjj » Tue Sep 13, 2011 9:16 am
Odc maniac wrote:PaPa_H wrote:Bro rjj,
As suggested by Bro Maniac...coilover will give you the immediate improvment on the handling and looks....it can be comfy too depending on the set up.
struct bar will futher improve the handling too....but there are more to be done,change and add on to really get the best out of it.
Having said all, unless you really push your ride to the limit, chances are you wont feel much loh except that there are almost no roll...
cheers
PaPa_H
Post
by PaPa_H » Tue Sep 13, 2011 9:04 pm
Will the coilover lower my ride? Mine is stock but the bodykit often hit the ground esp driving down from MSCP. Not sure if my front shocks due for change...
PaPa_H
Post
by PaPa_H » Tue Sep 13, 2011 9:16 pm
rjj wrote:Odc maniac wrote:PaPa_H wrote:Bro rjj,
cheers
Haha...thanks bro rjj. Comfy is still my priority over handling, so coilover may not suit my ride...further my rim size only 16"
If I just add strut and front lower bars, is it suffice? Was told to get UR bars in JB as it is much cheaper than here? Is it true???
rjj
Post
by rjj » Tue Sep 13, 2011 11:24 pm
cheers
you should be able to feel the different.UR is definately cheaper than jepun brand loh....not sure if it is cheaper in JB.
just to share, there are 3bar ontop. 1 in the engine, 1in the centre row 1 at the rear. i hv the front and rear.
there are five at the bottom, 3 at the front and 2 at the rear. btw, roll over centre is oso very good too. i hv all at the bottom...
PaPa_H
Post
by PaPa_H » Thu Sep 15, 2011 11:42 pm
bro rjj,
Need your advice...KM told me mine front shock about time to change and was quoted 1K!!! Faintz...
Checked around and if change to KYB Excel G - about 1k for 4. Should I get KYB or Coilover instead??? Mine ride is on 16" rim and 3.5 years to go. Can coilover provide the same level of comfy?
kemrodz163
Post
by kemrodz163 » Fri Sep 16, 2011 7:58 am
If you compromise on your shocks, the effect is on your tyre. Uneven wear and eventually bumpy ride.
rjj
Post
by rjj » Fri Sep 16, 2011 9:49 am
PaPa_H wrote:bro rjj,
coilover will definately improve the handling...as for comfy....it will be very subjective. if you are concern and want the comfy of ur ride now. replace it with stock or KYB. some bros are on KYB and they can provide honest feedback.
For me i will definately go for coilover...
cheer
PaPa_H
Post
by PaPa_H » Fri Sep 16, 2011 1:11 pm
kemrodz163 wrote:If you compromise on your shocks, the effect is on your tyre. Uneven wear and eventually bumpy ride.
Bro I dont quite understand? Care to explain more?
