Alternator spoilt common wear & tear?
YEN96
Post by YEN96 » Thu Mar 01, 2012 10:54 pm
wankie wrote:finally my turn for alternator to kaput after 5 years. got it changed at Kian Teong at Sin Ming Autocare, $480 for a new one. Not sure how much was labour as i did a bunch of other stuff as well since the car was in.
was there any warning signs prior to this ??
drive or tow to worksho p??
pReTeNd3R
Post by pReTeNd3R » Fri Mar 02, 2012 9:36 am
Hi, $480 for a new one? How sure r u? normally new is ard $700+. If its true then i wan to go there to change as i scare mine ll be up lorry anytime. :)
akuma19
Post by akuma19 » Fri Mar 02, 2012 10:31 am
best is to know how to identify re-con and brand new set
pReTeNd3R
Post by pReTeNd3R » Fri Mar 02, 2012 7:04 pm
How? :)
SpeedMaster1979
Post by SpeedMaster1979 » Fri Apr 13, 2012 11:49 am
My alternator failed me again after 1 year of usage from repair.Sent my car down this morning to a workshop in Sin Ming Autocare and was advised that usually its the rectifyer and regulator kaput, very common problem.He used a device to clip it on my battery and the red indictor light on alternator from the device light up with the battery and he explained that my battery is ok, still charging but alternator confirm kaput liao as if not,it will not light up.
Nevertheless,he will still need to dismantle out and check what needs to be replaced before letting me know the price but verbally told me $300 got change,sian!!!
Have to admit car really old liao.Starting to give me crap after i have replaced a burst air con piping last month.
Always when I hear air con compressor & alternator problem sends shivers down my spine as I can sense my vitamin flying out from my pocket again!!!
Speed is nothing without control
SpeedMaster1979
Post by SpeedMaster1979 » Fri Apr 13, 2012 11:52 am
Also heard from this workshop that CL7 has a frequent problem on alternator & air compressor kaput. I ask him any ways to maintain & he told me no way, wear & tear based on heng/sway or lifespan,
Sian manz! Have to make this topic under sticky liao as i beleieve many will kanna this(Touchwood) and this folder is easy to find.....
snowshake
Post by snowshake » Fri Apr 13, 2012 12:11 pm
You are not alone. 7th year, and i am into my 3rd alternator : )
ram lah ?ram lah.!.ask u not to ram..
xue
morse
Post by morse » Sat Apr 14, 2012 4:19 pm
Hi, $480 for new set is consider cheap. Mind sharing the contact person and number for the workshop.
I understand some bros paid $300plus for recon set. kindly advise.
viper76
Post by viper76 » Sun Apr 15, 2012 6:39 pm
$250 for recon set
Gunfighter
Post by Gunfighter » Wed Apr 25, 2012 8:20 pm
Ok..got this today, battery indicator also on..going to workshop tomorrow.
snowshake wrote:
xhareshx wrote:sorry, but how do u actually find out that the alternator is going to fail?
The engine bay give out a strange whinning sound loud when you ram the accelerator. It is not normal sound. You know, the next thing it is going down.
Gunfighter
Post by Gunfighter » Thu Apr 26, 2012 5:53 pm
What a morning for me. Car did not make it to the workshop..steering became hard, all lights were lit and the car stopped. I got to get a tow truck to come.
Fixed at my workshop. doesn't take long.
mbernard
Post by mbernard » Thu Apr 26, 2012 10:40 pm
gunfighter bro,
which workshop did you go to?
Gunfighter
Post by Gunfighter » Thu Apr 26, 2012 10:57 pm
I went to Chip Soon.
mbernard wrote:gunfighter bro,
morse
Post by morse » Sat May 26, 2012 1:01 pm
Gunfighter wrote:I went to Chip Soon.
might sharing more information.
1. how much for repair
2. new set or recon
3. downtime for the repair or replace.
4. address and contact of the workshop.
i sure your information will benefits alot of bros and sis here.
WSLBCL7
Post by WSLBCL7 » Sat May 26, 2012 2:17 pm
2. new set or recon
I had mine done last yr, here r some info:
New set: 600-800 depends on shops (inc install)
Recon set: 300-400 depends on condition (inc install)
Dwntime: abt 1-2hrs only
Shop: I checked with lots of shops they do offer almost the same cos i think it's universal, can be use for many models, i guess
