Alternator spoilt common wear & tear?
alternator
I have changed to a recon alternator about 2 weeks ago. Voltmeter reading still will drop below 11V and quite unstable every day, especially reverse, braking on slope, cornering, etc. Driving normally with aircon on and turning on ICE... This recon one has 1 month warranty. Battery changed 6 months ago.
Btw, there is a bad smell every morning startup for the past 1 week. Aircon also not cold liao since this morning. (Not sure if the smell and aircon are related to the alternator?)
Please advise me if I should change to new one.
Thanks!
Thanks!
- Yaloryalor
so you're the white CL7 i saw that day at SKMYaloryalor wrote:2 days ago suddenly hear a strange noise when I switch on the engine especially when I stepped on the accelerator.
When to SKM and ah Heng told me my alternator spoiled liao.
Paid $350 for a recon unit and problem solved.
He mentioned to me about your alternator problem when he took my car for test drive.
Drink... Drive.
Bloody idiot.
Bloody idiot.
- Yaloryalor
You are the white R?kobane wrote:so you're the white CL7 i saw that day at SKMYaloryalor wrote:2 days ago suddenly hear a strange noise when I switch on the engine especially when I stepped on the accelerator.
good memory, bro.Yaloryalor wrote:You are the white R?kobane wrote:so you're the white CL7 i saw that day at SKMYaloryalor wrote:2 days ago suddenly hear a strange noise when I switch on the engine especially when I stepped on the accelerator.
your "problem" seems more common, according to him.
mine is the odd one. hope he nicked it at the root. it's giving me headache haha.
Drink... Drive.
Bloody idiot.
Bloody idiot.
- Yaloryalor
Nice to see you!kobane wrote:good memory, bro.Yaloryalor wrote:You are the white R?kobane wrote: so you're the white CL7 i saw that day at SKM
Hi bros just to check how long it takes to change it? Also beside SKM the other workshop at sim ming is at which level.
My problem seems to be Alternator going to spoil as well. Just yesterday whie trying to make a turn my sterling wheel feels heavy and my radio just off by itself and on by itself again.
Everything is stock has not done any mod to mine car. After reading through what had happen i think i must go get it check as well.
You got batt logo coming out from yr meter side indicator there?Prelude wrote:Hi bros just to check how long it takes to change it? Also beside SKM the other workshop at sim ming is at which level.
If got, alternator up lorry Liao.
Nope bro did not seethe batt logo from my meter.... Thanks for this info will look out for this as well!!!!zhihong wrote:You got batt logo coming out from yr meter side indicator there?Prelude wrote:Hi bros just to check how long it takes to change it? Also beside SKM the other workshop at sim ming is at which level.
Last time I had that problem, I had my battery changed and it all went away.. lights, console, power steering etc.. sounds like the same thing..Prelude wrote:Hi bros just to check how long it takes to change it? Also beside SKM the other workshop at sim ming is at which level.
Bro thanks for ur feed back. Dun think its my batt cos i just change it in november 2011.Gymrat76 wrote:Last time I had that problem, I had my battery changed and it all went away.. lights, console, power steering etc.. sounds like the same thing..Prelude wrote:Hi bros just to check how long it takes to change it? Also beside SKM the other workshop at sim ming is at which level.
May b i should go back n get my batt check to see is there any problem with it
Try ubi , Blk 3005, batt shop. Heard from one of our bro here got it new + labour @ $610 total damage..XsenseX wrote:My alternator starting to up lorry too.
Just want to check any bros actually change to new one before?
I mean, if its around $700, i don't mind get a new one compared to $300 to repair with only 1 year warranty.
