CL7A part Nos
Ecopower
Post by Ecopower » Thu Oct 22, 2009 4:05 pm
I noticed that the fuel filter has a different part number from the earlier post.
Earlier part number -- 16010-SEA-000
Latest post part number -- 16010-SEA-010
Can the new filter be used in preface lift CL7A ?
cl7teckie
Post by cl7teckie » Fri Oct 30, 2009 1:53 pm
hahhaa....such thread oso can har?? there are 14,000 parts in our car leh!! :lol: :lol:
ml2spin
Re: CL7A part Nos
Post by ml2spin » Wed Feb 17, 2010 4:26 pm
sub wrote:Some part number for the A bros. collected from what i changed over the years. Price est from Tanly/Thian Seng
1. Compressor Belt - 38920-RBA-003 - $30
2. Fuel Filter - 16010-SEA-000 - $45
3. Rear Engine mounting - 50810-SDA-A02 - $115
4. Transmission upper mount - 20870-SEA-E01 - $55
5. Front engine mounting - 50830-SDA-A03 - $120
6. Water pump - 19200-RFE-003 - $105
7. HAMP oil filter - 15400-PLC-505 - $7
8. ATF filter25430-PLR-003 - $20
9. Side engine mounting - 50820-SEA-001 - $85
10. Right front door rubber - 72325-SEA-003 - $60
11. Left front door rubber - 72365-SEA-003 - $60
12. Stock ARB bushing - 52306-SDA-A01 - $10
13. Driver door actuator - 72115-SDA-A01 - $110
14. Left front door actuator - 42155-SDA-A11 - $120
Prices only as a guide. Bros who have more pls add in
I think the left front door actuator number may be wrong but I need to double check once Min Ghee or Thian Seng reopens for business.
Because when I went to KM's part dept and check out the CM part manual, the front right door actuator's part number is correct as above, but the left front one is 72155-SDA-A01.
It doesn't make sense to me that the CL and CM shares the same part for the right but not the left???
ml2spin
Re: CL7A part Nos
Post by ml2spin » Tue Feb 23, 2010 12:13 am
ok just bought the part from Min Ghee today -- confirmed it is 72155-SDA-A01 for front left door actuator.
Gingerfish
Post by Gingerfish » Sun Jul 04, 2010 12:37 am
latest price...from TS
1) Fuel filter - $50
2) So call Orginal Ac Belt - $65
3) Cooling pump - $120
4) Belt tensioner - $100
xhareshx
Post by xhareshx » Sun Jul 04, 2010 11:46 am
Gingerfish wrote:latest price...from TS
cooling pump = waterpump?
are these the addional parts tt are needed to be changed during the 80k servicing?
Gingerfish
Post by Gingerfish » Mon Jul 05, 2010 1:02 pm
Bro, actually this can be done at 140K according to TS unless coolant level is always low or leakage. I see that the location of it is actually in the mid section right above crankshft flywheel hence decided to do the renewal once and for all since i'm cange the belt and tensioner in one labour cost
xhareshx
Post by xhareshx » Mon Jul 05, 2010 9:22 pm
thanks how about fuel filter and atf fliter?
Gingerfish
Post by Gingerfish » Mon Jul 05, 2010 10:00 pm
Bro, i reckon Fuel filter can be change at 80 - 90K which is more than enough usage, cause when i saw the used filter, its like cloaked. And after renewing, ride does not feel sluggish during gear drop.
ATF filter should be change during ATF fluid change altogether since we are using new gear oil? every 30K or 2yr?
xhareshx
Post by xhareshx » Wed Jul 07, 2010 7:55 pm
Gingerfish wrote:
xhareshx wrote:
Gingerfish wrote: Bro, actually this can be done at 140K according to TS unless coolant level is always low or leakage. I see that the location of it is actually in the mid section right above crankshft flywheel hence decided to do the renewal once and for all since i'm cange the belt and tensioner in one labour cost
thanksbro. have to go get all of them changed
KuroCL7R
Post by KuroCL7R » Tue Sep 21, 2010 2:43 pm
Just wondering if the part no from CL7A is also applicable for CL7R?
I'm looking for part no for fuel filter & front left passenger actuator for CL7 EuroR
Thank for sharing
ml2spin
Post by ml2spin » Wed Sep 22, 2010 2:19 pm
KuroCL7R wrote:Just wondering if the part no from CL7A is also applicable for CL7R?
Thank for sharing
Yes same.
KuroCL7R
Post by KuroCL7R » Thu Sep 23, 2010 10:56 am
thanks bro
yeepin
Post by yeepin » Sun Sep 26, 2010 1:13 am
Can I know here to get the orginal front number plate holder? N how much? Thanks alot.
_________________________
Always so stock, Forever so slow.
KuroCL7R
Post by KuroCL7R » Mon Oct 04, 2010 12:43 pm
Ecopower wrote:I noticed that the fuel filter has a different part number from the earlier post.
So, what is the correct fuel filter part number? tq
