Just sent my city for tyres roatation @ Autobacs and they inform me that my front left shock absorber arm had worn out and it is causing uneven wear on my tyres. They quoted me $1700 for the whole set.
I have a few questions hope you all bros can advise me as I am new to this shock absorbers thing:
1) I do not know the brand they quote me, but is $1700 a resonable price?
2) changing the whole shock absorbers includes the suspension as well?
3) should I go back to Kah motor to let them verify this if this is true?
any bros can recommend me a good workshop to change it and not so expensive? $1700 is indeed costing my pocket a big hole.
Tks all in advance.
Shock absorbers
Re: Shock absorbers
not an expert nor car mech. but here's my answer based on what i know / done:HappyCity wrote:Just sent my city for tyres roatation @ Autobacs and they inform me that my front left shock absorber arm had worn out and it is causing uneven wear on my tyres. They quoted me $1700 for the whole set.
Tks all in advance.
S$1700 is a lot for dampers only. i changed all 4 (mine is 4G year 2006) for much less at vision garage.
shock absorbers (also known as dampers - better name as it is what it does) is a part of what we call suspension. the whole suspension system consist of frame, springs, dampers, and so on.
going back to KM will be expensive, else can check out the list of workshops in general discussion or call the shop i go to for advice.
Re: Shock absorbers
Thanks for your recommendation, I had done mine at Malaysia.isvtec wrote:HappyCity wrote:Just sent my city for tyres roatation @ Autobacs and they inform me that my front left shock absorber arm had worn out and it is causing uneven wear on my tyres. They quoted me $1700 for the whole set.
Tks all in advance.
