Anyone Is Planning For A Trip To WS in JB Soon?
Civic model year 1980 - 2000
yeobt
Postby yeobt » Sat Apr 14, 2012 12:12 pm
i think i need to service my EK soon.
anyone interested to tag along maybe on 18 April (weekday)?
also, i can hear a fair bit of sound generating from the front wheel,
suspecting is drive shaft or wheel bearing, any idea?
After Spending So Much Time And Money To Own A Car,
You Must Learn To Enjoy The Fun Of Driving It,
Not Stressing Yourself On Your Journey Home.
Will_SG
Re: Anyone Is Planning For A Trip To WS in JB Soon?
Postby Will_SG » Sat Apr 14, 2012 10:16 pm
yeobt wrote:i think i need to service my EK soon.
sound when turning only or when moving straight.
yeobt
Postby yeobt » Sun Apr 15, 2012 10:55 am
No kok kok sound when Turning. But is generating Wong Wong sound while
moving especially at higher speed. Like driving buses. :P
Will_SG
Postby Will_SG » Sun Apr 15, 2012 1:36 pm
wong wong sound = high chance bearing issue
yeobt
Postby yeobt » Sun Apr 15, 2012 1:50 pm
how much it costs to replace in ringgit? :P
few more things to do at the same time.
ah_rek
Postby ah_rek » Sun Apr 15, 2012 4:21 pm
what spec of your gearbox you change ?
if it happens after you change your gb, and it gets louder when you accelerate, then it's cfm your gb liao.
slow is gold.
yeobt
Postby yeobt » Sun Apr 15, 2012 9:31 pm
ah_rek wrote:what spec of your gearbox you change ?
the mech didnt reveal the exact spec, only says is stage one close ratio.
no, i think it happens after i drove my left wheel into a CB pot hole inside a CP. :twisted:
flava
Postby flava » Mon Apr 16, 2012 2:29 pm
on the topic of gb, i intending to do an upgrade on my b-series, however worried abt cruising speed... can i know after u upgrade, whats your 5th gear rpm @ 100km/h?
"hi bro, your items can cheaper bro??"
yeobt
Postby yeobt » Mon Apr 16, 2012 3:49 pm
2500 @ 100km/h
kozmix
Postby kozmix » Mon Apr 16, 2012 4:37 pm
2500 @ 100km/h
wtf , 2500 @ 100km/h, worse than ESI stock gearing.
your mech actually tell u is close ratio gearbox ?
pls share the workshop name so all bro here can avoid.
You know you're so JDM when your black underwear have red stitchings.
ah_rek
Postby ah_rek » Mon Apr 16, 2012 4:56 pm
I warned u, do ur homework before changing anything stupid which leads to double the price to get what u actually need. Either buy genuine parts or know what u are getting. In this case u learned the hard way like all of us.
There is no stage 1 close ratio, no close ratio @2.5k rpm cause It serves no purpose!
*ps pls publish the workshop who recommend the stage 1 close ratio, guess the future newbie can also avoid.
slow is gold.
yeobt
Postby yeobt » Mon Apr 16, 2012 5:56 pm
You guys know la, I'm new on this GB thing so what should be the correct rpm?
Also, at this 2500@100, what does it tells? Not even close ratio?
But the setup is good enough for street use, better then before n the FC is not affected.
flava
Postby flava » Mon Apr 16, 2012 6:27 pm
yeobt wrote:You guys know la, I'm new on this GB thing so what should be the correct rpm?
im puzzled, a stock EK3 gb at 100kmh, rpm at 5th gear will be 2.8k, given that ive driven it before.
2.5k rpm cruising is much lower than stock already so where's the close ratio in that? perhaps you should check out the history of your box and its gears, cos it really seems that your build is taking a step backwards.
anyway, if you can feel the difference and more enjoyable, who's to criticize? just that the figures dont add up.
to give you a better gauge on close ratio, im on an EK9 gearbox, 4.4FD. this already gives me 3.4k rpm @ 100kmh. and its stock!
Will_SG
Postby Will_SG » Mon Apr 16, 2012 7:42 pm
Maybe his RPM gauge is inaccurate. Yeobt what was your rpm at 100km/h before u change the GB?
yeobt
Postby yeobt » Mon Apr 16, 2012 7:50 pm
2k @100 before GB changed.
I'm on my way home, will try to push my civic @100 to see the effect. :P
Return to “Civic EF / EG / EK”
Who is online
