How much petrol can be squeezed into ES5 tank?
How much petrol can be squeezed into ES5 after the first click?
After the first click, if i continue squeezing, after 1 or 2 litre, can start to see the tank like a bit overflowing. after a while, the level drops, then can continue to pump. It seems that i can go on pumping forever, machiam like got some overflow valve that let excess petrol flow out. So i usually stop at about 4 litres after the first click.
Anybody tried filling to the very brim?
Left home wif less den half tank, lights up in seremban, now in KL just now at caltex pump total 52ltrs after first click, was pumping 95r so pause 2 more click, and quickly get lost. Highest ever pump. 49ltrs but 52ltrs (rm99) chua tio. Tank leaking.?
Don't try this at home.
- Krado
Re: How much petrol can be squeezed into ES5 tank?
That is because fuel that comes out from the nozzle is full of bubbles. Once the bubbles escape, more space left.joelwong wrote:machiam like got some overflow valve that let excess petrol flow out.
- MCDS
- Civic ES/EU/EP Moderator
joelwong wrote:that one look even stupider than humping the carMCDS wrote:jack up your car on the fuel inlet side to as high as possible... 60 degrees preferable but you will need special jack to do that.
then you can fill up to 70 litres of petrol into your car.
ahhh... you must be a newbie young driver... never seen the action in JB when woodlands was still on the old checkpoint complex using Jalan Wong Ah Fook...
That Caltex station cater 99% Singapore registered cars... one of their pump got a one side ramp to allow your car to tilt to that kind of angle for your conveience... and they got part time boys help your to bounce your car to shake off the air bubbles in your fuel tank for a ringgit or two depend on your mood..
damn solid...
wa..now the shell station got anot? fill up to 70 litres, that means 20 litres after the first click ar?MCDS wrote:joelwong wrote:that one look even stupider than humping the carMCDS wrote:jack up your car on the fuel inlet side to as high as possible... 60 degrees preferable but you will need special jack to do that.
damn solid...
- MCDS
Essentially, the ES 5 has a 50litre capacity gasoline tank and has made some additional space for air to breathe and expand as a safety feature.
you want to pump to the brim it should be around 50 plus a bit - that is the maximum safe volume your tank can hold.
why are you trying to put in that extra few litres? just so you can save a bit more?
just come back and top up again when that 50 is used up lor...
si beh ti ki... ask funny question ... and saving that $5 ? at the risk of your car BLOWING UP due to overfill and overflowing fuel tank meeting Mr spark...
of course can ask for fun la... so we also give you for fun answer and describe what we see KIA SU singaporean do at JB... everybody laugh until stomach ache... stoopid sinkapolearn... damn ku ku cartoon type... yes they got money - buy big car lar stoopid... fuel tank 130 liter capacity fill until you shiok... a few litre so huan noh to squeeze in... boh lui mai hua chia...
