Hello everyone,
My soft top has a tear/hole due to wear and tear! but lucky me water does not get in and i have parked in the rain many times! Anyone replaced their soft tops before? Can recommend where i can get a replacement? How much do replacement soft tops generally cost? Thanks in advance..
Soft Top replacement
Re: Soft Top replacement
Can get from Joel from Driven... And install at 8 cushion...cost will depend on material used but min should be about sgd1000 excluding installation which is a tedious processDCS2K wrote:Hello everyone,
Thanks Youri for your reply... Much appreciated!
Karlmax, im assuming you are Joel from Driven? YES@! i would like to take a look at your softtops, how do i contact you? is this your website address? http://www.drivencrazy.sg
you can reach me at [email protected]DCS2K wrote:Thanks Youri for your reply... Much appreciated!
website is www.driven.com.sg
www.drivencrazy.sg is the blog, which has been a little lackluster of late.
the ones i sell are from EZ-on tops. they are the stayfast material, and not the vinyl ones which are original.
the stayfast material is the same material that comes factory on the german-made convertibles
they are $1000 a pc.
Hey man, Thiam Seng doesn't do the installation but they will deliver the item FOC to whoever you appoint to swap the cover. I got GarageR to handle the installation (fee involved).DCS2K wrote:Fireshine, does Thiam Seng do installation as well? If so, whats the cost? Is what you ordered original or OEM?
