S2000 stuff for sale!
WTB: Shin Etsu Grease
Hi, I am looking for a tube of shin Etsu grease. Any idea where can I find one? Or anyone is letting go his tube? Used ones are fine too
Re: WTB: Shin Etsu Grease
Look for joel 9487-5000HotSausage wrote:Hi, I am looking for a tube of shin Etsu grease. Any idea where can I find one? Or anyone is letting go his tube? Used ones are fine too
Re: S2000 stuff for sale!
Good condition S2000 Steering wheel for sale. Text me at 9423966O as I seldom login.
Clutch pump master & slave
Stock S2000 Cat
Stock S2000 Exhaust
Stock S2000 Header
Call 9 73 73 73 2
Stock S2000 Exhaust
Stock S2000 Header
Call 9 73 73 73 2
- civic_aprilia
- 5000rpm
Stock AP2 final drive for sale. Used approx 1,000kms
- Attachments
- image.jpeg (83.58 KiB) Viewed 5842 times
Clearing store room sale.
S2000 STOPTECH STEEL BRAKE LINES - FRONT for $100 https://carousell.com/p/29391407 on #carousell
S2000 HAWK HP+ PLUS BRAKE PADS - REAR for $90 https://carousell.com/p/29391698 on #carousell
GENUINE HONDA S2000 BONNET / BOOT LID BADGE EMBLEM 2002-2009 for $22 / $25 https://carousell.com/p/28658192 on #carousell
Honda S2000 Stock Rims for $100 each
https://carousell.com/p/29569893 on #carousell
HONDA S2000 STOCK BRAKE CALIPERS - FRONT for $250
984one953seven to deal. Cheers!
CG Amis engine oil cap for sale.
In very good condition. $100
PM if interested.
http://www.nengun.com/car-garage-amis/oil-filler-cap
PM if interested.
- Idling
Wtb: J's racing single exhaust 70rs or 70rr. No cert
Thanks
Thanks
Honda S2000 OEM parts for sale
OEM Side Mirror - $180
OEM Catalytic Converter - $200
+6738 857938 =)
+6738 857938 =)
Hi all, have the following to sell.
2) Modifry seat belt lock with remote. $80. RHD version, works well with stock seat on track.
http://www.modifry.com/products/sbl/index.htm
3) K&N FIPK replacement filter. Brand new in box. $130.
4) Type s stock steering wheel. Very good condition. $350.
PM if interested. I still have several stock items like stock lsd, front and rear upper arms with almost brand new powerflex bushings, front anti roll bar with powerflex bushings, front calipers and rotors, rear rotors, rear control arms to clear.
Interested pls msg me at 98774157.
WTS: OZ Racing Alleggerita HLT rims + Yokohama AD08r Tyres
OZ Racing Alleggerita HLT Monobloc rims (original MADE IN ITALY)
Color: Original Matt Black
PCD: 5-114
Sizes: 17 x 7" +49mm / 17 x 8.5" +59mm (1 pair per size)
Weights: 6.6 kg / 7 kg (one of the lightest cast rims available)
Materials: Al Si 7 Mg
Original carbon fibre OZ center caps included
Condition: Zero Rashes Zero Dents
Sizes: 245/40-17 (4 pcs) + 215/45-17 (2 pcs) - (Total: 6 tyres - all used)
Asking only $1000 (nego) for everything.
Kindly whatsapp 985O 7825
PCD: 5-114
Alloycraft rear diffuser
Hey there, got the above going @ $200.
Interested contact me @ 90255954, thanks.
Toda F20A/F22C TODA High Power Clutch FULL for AP1/AP2 Ty
Selling F20A/F22C TODA High Power Clutch FULL for AP1/AP2 Type S.
comes with Toda original flywheel ultra-light Cr-Mo flywheel
used conditioned 8.5/10
$1250/set
Contact / whatsapp anytime : 96868644
email.: [email protected]
Improvement in clutch response
A strap drive system connecting the pressure plate to the cover is used, improving both the response of the clutch pedal operation as well preventing noise commonly found when the clutch is depressed.
A low inertia disc
A high friction valve, low wear rate, and a metal material with high heat resistance made into a compact size (ø200mm). Gives you a high power transfer capacity and a long life. A small damper disc specially designed, and optimization of the metal pad including its thickness. Greatly reducing inertia to below that of the original product. Giving enhanced shift feeling and reduced synchronizing wear with in the gearbox.
High quality. Chromium molybdenum flywheel
Stress analysis, balance, and inertia are simulated using CAD solid models for optimized performance. An overall design, designed to give good weight savings and low rotation characteristics.
$1250/set
A low inertia disc
- Attachments
- toda full clutch_f22_f20c-engine.jpg (74.65 KiB) Viewed 4981 times
- Idling
WTB: S2000 Alternator
