previa333
Post
by previa333 » Tue Oct 05, 2010 10:50 am
any bros have any experience with ody engine with regards to engine oil loss? Mine is getting worse from Max to Min with just 1k travelled. Any flaws with any seals on K24 engine or leak from sensor?
rjj
Post
by rjj » Tue Oct 05, 2010 6:33 pm
previa333 wrote:any bros have any experience with ody engine with regards to engine oil loss? Mine is getting worse from Max to Min with just 1k travelled. Any flaws with any seals on K24 engine or leak from sensor?
do you see any oil stain under your ride after you park your car over nite?
suggest you get the professional to do a scan where your oil go to....before you cooked it....
Odc maniac
Post
by Odc maniac » Tue Oct 05, 2010 11:13 pm
U mean odc engine oil will decreased over time??
Sounds scary. I'm on rb1 and does that mean I need to check engine oil level at fixed interval I.e. Weekly?
previa333
Post
by previa333 » Tue Oct 05, 2010 11:48 pm
rjj wrote:previa333 wrote:any bros have any experience with ody engine with regards to engine oil loss? Mine is getting worse from Max to Min with just 1k travelled. Any flaws with any seals on K24 engine or leak from sensor?
mechanics found nothing as the oil plug and sump all very clean with no stains. Parked overnite but find nothing on the floor. No white smoke or anything wrong. This is strange
steve_tth
Post
by steve_tth » Wed Oct 06, 2010 9:41 am
my issue is also the Engine Oil. From Service @ KM and after 5000km of travelling, the Engine Oil dip will drop from MAX to bare min over time... Mine also has no signs of spills or leak after SA also checked. No white smoke nor any symptoms as well.
But yours drop in 1k Travelled is abit
$ use for engine oil will be a bomb.
previa333
Post
by previa333 » Wed Oct 06, 2010 9:53 am
if really got no solution, then have to use cheaper mineral oil. Since frequent topping up means ample supply of fresh oil lol
wolf
Post
by wolf » Wed Nov 17, 2010 4:16 pm
Happened to me too during warranty period. Kah Motor put a dye in the engine to try to trace the leak, could not find anything. Think they decided changed some of the seals, but this is a major job.
steve_tth
Post
by steve_tth » Sat Nov 20, 2010 9:48 am
hmm.. seems like K24 Engine oil leak in Ody is not a uncommon issue...
kurby
Post
by kurby » Mon May 23, 2011 9:36 pm
Sorry to bring this up again...I am also experiencing this loss of engine oil...but mine not so bad...5K lose to min...have to top up again.
Same din find any leak or stain on floor...no white smoke as well...
Anyone has any solution or are all RB1 owner facing the same issue?
Odc maniac
Post
by Odc maniac » Mon May 23, 2011 9:47 pm
What oil u using?
Heard that mugen oil tends to evaporate/loss over time.
I'm using mobilone gold. No issue.
kurby
Post
by kurby » Mon May 23, 2011 10:35 pm
Use shell helix and also ows uberlight...same issues...
rjj
Post
by rjj » Tue May 24, 2011 12:54 pm
what is the oil rating used?
try not to use too thin
mathew
Post
by mathew » Tue May 24, 2011 4:47 pm
I never routinely check the level of oil...
How often do you all do that?
steve_tth
Post
by steve_tth » Tue May 24, 2011 5:14 pm
I'm using Fully Synthetic Oil.
Bro Rjj... I think my problem is common.. so many bros got it.. must be a defect in K24 engine.
Can complain Japan anot ah... then get a type R engine in..
rjj
Post
by rjj » Tue May 24, 2011 6:55 pm
steve_tth wrote:I'm using Fully Synthetic Oil.
Type R stil cant keep up with the 6 u have lah.... so far i nvr check oil level
if the level too low the oil temp will definately go up so if my meter dun show i guess it should be alright loh....
btw just had my gear box overhaul....same as my engine...done it one yrs ago..now all new and strong....hee
