wat could be the problem ?? Time for overhaul?
Need to open engine up to check ??
It's getting noisy after I changed exhaust from header all the way back. Tuning run?
Car not as powerful as before, seems losing compression n engine sound rough.
Engine getting n noisy n feel rough
For such symptoms, check for vacuum leak first..all air related.
The cause is unnecessary excessive air seeping in..firing, fuel, air all haywire for such symptoms...air or vacuum leak should be around pipings, tube and intake manifold, throttle body, any bolts loose, intake mating head surface , IaCV working .??
Solved...car now shiok shook smooth.
