Whenever it rains a small puddle of water will form at the spare tyre area
I did some read up and it seems that my tail light gaskets have hardened over time allowing water to seep through, which is a common issue for integras.
Does anyone know where I can fix the seals?
water leaking through tail light gaskets
- 6000rpm VTEC ON
Re: water leaking through tail light gaskets
Hi Bro,philipho wrote:Hi,
Have you found any place which sells the taillight gasket? I have checked with Thian seng and they do not have stock.
What I did is just stick up the back of the gasket and it seals up fine.
Thanks!
Kah motor sells the gasket, but they require you to go down personally to order from them.
I managed to fix the leak by removing the bumper + tail lights, cleaning the dirt and applying a layer of silicon on the gaskets.
- 3000rpm
The most common and perm fix is to drill a hole in the tailights. the fishtank effect will come back no matter how you fix it
HAHAH yup thats what I did for mine as well. drill 2 holes in each corner of each taillight.
Bad design is the issue. Even NSXs had this problem........
